Three 3 home signal box and TG582n FTTC configuration
Is there any special configuration required on the Technicolor TG582n FTTC router with the Three home signal 3G devices because I can get a reliable connection/setup. Three have supplied two of these so far but neither work with the router.
thanks in advance
3 REPLIES 3
Fixes: 7
Re: Three 3 home signal box and TG582n FTTC configuration
Didn't know "Three" had one these type of devices, the ones supplied by Vodafone O2 etc appear to be troublesome -- don't expect this one to be much different.
I use the "Three inTouch" app on my phone, does much the same thing and has worked perfectly for me over the past 6 months.
http://www.three.co.uk/discover/three_intouch
+1 for "Three inTouch", which also works with PAYG Roll_eyes  It does use more battery, though, if you do not normally have WiFi enabled Shocked
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Champion
Fixes: 12
I uninstalled that piece of trash (Android version).I found it pretty much unusable and very annoying.
