Three 3 home signal box and TG582n FTTC configuration
- Re: Three 3 home signal box and TG582n FTTC config...
18-10-2014 6:27 AM
Is there any special configuration required on the Technicolor TG582n FTTC router with the Three home signal 3G devices because I can get a reliable connection/setup. Three have supplied two of these so far but neither work with the router.
thanks in advance
thanks in advance
Message 1 of 4
(1,477 Views)
3 REPLIES 3
Re: Three 3 home signal box and TG582n FTTC configuration
18-10-2014 9:25 AM
Didn't know "Three" had one these type of devices, the ones supplied by Vodafone O2 etc appear to be troublesome -- don't expect this one to be much different.
I use the "Three inTouch" app on my phone, does much the same thing and has worked perfectly for me over the past 6 months.
http://www.three.co.uk/discover/three_intouch
Message 2 of 4
(1,032 Views)
18-10-2014 9:49 AM
+1 for "Three inTouch", which also works with PAYG It does use more battery, though, if you do not normally have WiFi enabled
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 3 of 4
(1,032 Views)
18-10-2014 11:04 AM
I uninstalled that piece of trash (Android version).I found it pretty much unusable and very annoying.
Message 4 of 4
(1,032 Views)
