Thinking of upgrading back to 80/20
shrubb2121
Hello lovely members
I'm thinking of moving back to 80/20 speed as I cant handle having 2mb upload speed I've noticed my plusnet hub one router is sync at 39.999/1.999 does this mean plusnet will need to arrange having my profile set to max that my line can handle from fibre cabinet.
Paul
Fixes: 62
Re: Thinking of upgrading back to 80/20
it should  happen automatically as part of the order to change to 80/20
Fixes: 162
If you upgrade to Unlimited Fibre Extra, we'd place a modify order for your line and this would change the profile available on the line to the maximum up to 80/20
 Chris Parr
 Plusnet Staff
