turn on suggestions
Thinking of changing package.
- Thinking of changing package.
08-09-2015 11:38 AM
Hi
I am on Unlimited Broadband with a no contract package. Can someone tell me how long it would take to change to Unlimited Fibre Extra, and what is involved. At the moment I use a Fritzbox 7390 router, would I still be able to use this.
All replies and advice welcome.
Mat
Mat
Re: Thinking of changing package.
08-09-2015 11:50 AM
The Fritz!Box 7390 can be used with Plusnet Fibre (FTTC) products, either as a router connected to the BT modem or as a modem-router connected direct to the VDSL (eliminating the BT modem).
There are old threads on here giving the required settings for use as modem-router, might be difficult to find now so just ask if you need help when you get to that point.
Call me 'w23'
08-09-2015 12:06 PM
As to what is involved, assuming your exchange and cabinet are fibre-enabled then all you need to do is ring customer services and request an upgrade. BE WARNED, though: they will not automatically give you the best deal possible for your line, especially if you are on a Market 3 exchange.
My advice would be to do some research on what deals other providers are offering. PN will normally match any competitor deal but will not volunteer it in my experience. Customer support have a maximum they can go to but if you stick to your guns they will transfer you to the retentions team who are able to offer more.
By way of example I was offered a £2.49 discount on the normal £27.49 price of Unlimited Fibre Extra for being a long-standing customer. Retentions then reduced that further by another £2.50. However, when I told them that I was considering going to SKY as they had an offer for £10 for the first year and £20 thereafter, PN matched that by doing £15 for two years (which works out the same), a discount of £12.49 off the normal price. So it pays to go in forearmed!
I've also had a bit of an administrative nightmare making the change, so beware of the potential of having this messed up more than once. First my order didn't go through properly, then my engineer didn't show up (after ringing to confirm a few days before and being told everything was as scheduled. Then my expedited order was not followed up. Then I was put on the wrong product (i.e. not Extra) and told I had to wait until the original order went through and change after installation, otherwise I would have to start again. Then my modem wasn't sent out (I had the correct faceplate so went for a self-install). Then my discount was incorrectly applied for a year (instead of two).
In the end the installation went smoothly yesterday and all being well my upgrade to Extra should happen today. But I've had to spend in excess of four hours on the phone (including being on hold) to PN this last ten days just sorting out issues due to poor communication / follow up between PN and BT. It's a very decent price in the end, but it's certainly not always headache-free. Be prepared to learn patience and make sure you phone them regularly for an update. If I hadn't I've no doubt I'd still be waiting for mine.
08-09-2015 12:07 PM
Thanks w23 for that info, most welcome.
08-09-2015 12:12 PM
Thanks "shure" I will keep that all in mind
