Thinking of Moving from BT infinity to Plusnet fibre - worth it?
yessuz
basically, got totally unlimited, not managed, 76 mbit down, 20 mbit up plan.
but similar plan from plus net is quite cheaper..
but what about traffic management, shaping and upload speeds?
MrSilver
Fixes: 9
Re: Thinking of Moving from BT infinity to Plusnet fibre - worth it?
Your speeds will be pretty much the same as plusnet buy the bt broadband product from bt wholesale, so upload/download will be same.
the shaping is not like people used to think of it, plusnet shape your connection individually to prioritise say voice and gaming over windows updates etc, so plusnet arent throttling video/p2p over other traffic at peak times, just kaximising what speed your connection if for traffic(according to their shaping pages!)
yessuz
hm, sounds good.
and are there any limits for the upload? for example - if I upload like 3 gb/hour then my up speed is capped as let's day 50% or so?
Plusnet Staff
Plusnet Staff
Fixes: 115
A warm welcome to our community forums @yessuz
Our Unlimited Fibre Extra package is advertised as 76 Mbps downstream, and 19 Mbps upstream, however, it's based off the wholesale product of 80/20.
As for traffic management, it's more of prioritisation within a household. This link explains how it works:
https://www.plus.net/help/broadband/about-traffic-prioritisation/
I hope this helps
[Edit]
Just removed the dot in the upload figure to indicate the correct speed for Fibre Extra. Apologies.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
Plusnet Staff
Plusnet Staff
Fixes: 115
I see MrSilver got there first.
To answer your question, no we don't limit uploading.
 Plusnet Support
yessuz
please clarify - 1.9 or 20 mbit upload? kind of 10 times difference here!
Plusnet Staff
Plusnet Staff
Fixes: 115
Apologies for that, just noticed it and edited my post. Fibre Extra is advertised as 19 Mbps upstream.
 Plusnet Support
JanAitken54
Don't move to Plusnet Fibre... for last few weeks have had only 2MB download as and upload! No information on web or here as to when it will get fixed.
Will be switching immediately to another provider.
dsalazar
Slow speeds, packet losses, inaccessible sites (Steam Store, Reddit) have plagued Plusnet the last few days.
Keep away until they they sort this out.
0rangecake
Go with someone else. Constant problems with PN.
MrSilver
Fixes: 9
I'd ageee they had some issues recently, but for me it wasn't constant and always effecting me, since last night it's much better will see if the fix lasts.
I used to be on BT infinity and would say I've not had more problems here than there.
yessuz
well, this worries me a bit, as I have absolutely no issues with BT. Well, just price...
Andrue
I've been here since early '14. There was a six month period during the first half of '15 when every couple of months I'd end up on a poor connection but bouncing my connection usually fixed it. It was annoying but more from the a technical point of view because it took so long for them to resolve it.
But in terms of actual days of poor connectivity I'd say less than a week's worth in 2.5 years.
The only thing I usually criticise PN about is their support (excluding this forum) and the silly [-Censored-]-ups that seem to plague their installation process. Once you've got your connection running the way you want in my experience it continues to deliver at full speed 24/7 most of the time.
I've been out of contract for over 18 months now and I'm a regular contributor to various technical broadband forums and I'm still here. The only technical thing I could fault PN about is the lack of IPv6. Not that it prevents me doing anything but it's getting a bit silly now.
yessuz
right, many thanks for the input!
I still have few days to decide where to go.
another option, of course, Virgin. but their upload sux a bit. so not really sure.
got kind of three options now:
- stay with BT. the "green cabinet" is like less than 100 meters away from the house..
- go with PN. Using same infrastructure as BT,
- go to Virgin (existing virgin connection to the house is present).
decisions, decisions...
Andrue
The only comment I'd have about Virgin is that they do tend to run their network 'hot'. This means peak speeds often drop significantly in the evening (but still usually higher than you'd get over your telephone line). The real issue is that if you're a gamer their network can also suffer from high levels of jitter and latency.
