Think i may have a faulty router.
- Think i may have a faulty router.
25-12-2018 11:27 AM
Re: Think i may have a faulty router.
25-12-2018 4:04 PM
Welcome to the community forums @Dave81, sorry to hear you're experiencing problems with your router.
Do you only experience the problems on Wi-Fi or do you lose the connection on wired devices at the same time?
Could you also confirm if this happens across all devices trying to search for the router over Wi-Fi.
Thanks.
25-12-2018 4:41 PM
25-12-2018 4:59 PM
If you haven't already done so, it may be worth splitting off the 2.4Ghz and 5Ghz frequencies in the router.
A helpful post explaining how to do this can be found Here.
If you connect to 2.4Ghz as opposed to 5Ghz, you may see a drop in wifi speed, however I have seen people in the past mention problems with devices dropping the connection to the router when flipping between the two frequencies when they're both synced up together.
27-12-2018 8:16 AM
27-12-2018 10:42 AM
Hi @Dave81,
As a precaution I'm going to replace the router to make sure this isn't the cause of the problem. It should be with you in a couple of days (bank holidays depending).
30-12-2018 9:45 AM
30-12-2018 12:40 PM
Hi @Dave81,
What firmware is on this new router (and the old router if you can get it - no worries if it's a pain, though). You can find it under troubleshooting and then helpdesk in the router config pages (192.168.1.254 to get there).
30-12-2018 2:18 PM
30-12-2018 4:18 PM
Hi @Dave81, thanks for your post.
On checking your line we can see the below:
GEA Test Detail | |||
Circuit ID | REDACTED | Service ID | REDACTED |
Test Outcome | Fail | ||||
Test Outcome Code | GTC_FTTC_SERVICE_1615 | ||||
Description | Potential HR Joint or wet joint detected on GEA Service. Please continue to submit a trouble report | ||||
Main Fault Location | CE | ||||
Sync Status | In Sync | ||||
Downstream Speed | 76.3 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | Y | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 286.5 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Regular Interference Observed on Weekends | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 14:00 to 14:15 | ||||
Interference Location | Unknown | ||||
Interference Observed In Days | 2 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2018-12-17T16:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 26.5 Mbps | 79.9 Mbps | 56.9 Mbps |
Up Stream Line Rate | 0.1 Mbps | 20.0 Mbps | 12.7 Mbps |
Up Time | 733.0 Sec | 900.0 Sec | 898.8 Sec |
Retrains | 0.0 | 20.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-12-30T15:45:59Z | 2018-12-30T16:00:59Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Due to the above results we've raised a fault with Openreach and now expect an update within the next 3 working days, at which point we'll contact you directly.
You'll receive notification that we've opened a question on your account shortly - At this point we don't need a reply to it, it's merely our process.
Please don't hesitate to get back in touch should you need anything else in the meantime.
30-12-2018 6:46 PM
30-12-2018 9:14 PM
Hi @Dave81, it's often the way with these things.
Whilst I, of course, can't guarantee that we won't find there to be an issue with the router at some point, it certainly seems as though this fault is the cause of your issues.
Please let us know if you need any further help in the meantime.
