Thankyou folks :) Adverts or PlusNet profiling slowing page loading help?
- Thankyou folks :) Adverts or PlusNet profiling slo...
09-03-2015 10:58 AM
I've noticed over recent months that many web pages take many seconds to load and convinced it's down to adverts loading judging by what I see on the status line.
I've got more or less 35Mbps download via FTTC, so I wonder if anyone can advise on whether this delay in loading, where some pages take 10 secs before you can scroll down the results is down to the congestion of the advert source or whether it is a PlusNet priority issue?
It just seems to be getting worse and I don't see the same delays when using a neighbours BT Infinity provided connection.
I had to change my homepage from MSN UK to Google UK to speed up the point where I could do a search as the MSN site took forever
It's not a PC, tablet or a laptop issue as I have many to choose from.
Not a complaint, just curious
Re: Adverts or PlusNet profiling slowing page loading help?
09-03-2015 11:18 AM
EDIT
Need to go to Specsavers - moved to Fibre
09-03-2015 12:00 PM
Also which browser are you using and have you tried another one to see if the same thing happens
09-03-2015 4:57 PM
Thanks for putting into a better queue
As previously mentioned I have multiple PC's, laptops, tablets etc running a mix of XP, Vista, Windows 8.1 and have IE various versions , Firefox, Chrome plus their Android versions too.
The main pages load almost instantaneously but then the 'loading' rotating symbol spins and several seconds later all the ads and junk appear and then I can scroll down the page.
I thought being on FTTC unlimited etc there was no traffic profiling (that may have hanged in the years though) and have opted out as best I can of all targeted ads.
Attached two Thinkbroadband speedtest results - the horrible one first and the older version I prefer second seems to suggest not a 'speed' issue.
I wonder if there is a debug tool to record just what is being downloaded and times when I open a web page?
Extra info below and hope my jpg's attach
From my control panel:-
Estimated line speed:There's no speed estimate currently held on your account. Current line speed:37.2 Mb
VDSL Stats below.
# xdslcmd info --show
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 7279 Kbps, Downstream rate = 44576 Kbps
Bearer: 0, Upstream rate = 7302 Kbps, Downstream rate = 38520 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.6 6.1
Attn(dB): 24.3 0.0
Pwr(dBm): 12.6 3.1
VDSL2 framing
Bearer 0
MSGc: 18 26
B: 51 223
M: 1 1
T: 64 40
R: 12 8
S: 0.0430 0.9743
L: 11920 1905
😧 753 1
I: 64 116
N: 64 232
Counters
Bearer 0
OHF: 605162844 941757
OHFErr: 5880 6280
RS: 302773618 1071367
RSCorr: 13774417 5453
RSUnCorr: 251106 0
Bearer 0
HEC: 59382 0
OCD: 2674 0
LCD: 2674 0
Total Cells: 3422495253 0
Data Cells: 2059027580 0
Drop Cells: 0
Bit Errors: 0 0
ES: 13350 25353
SES: 65 6
UAS: 412 371
AS: 1670120
Bearer 0
INP: 3.00 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.75 9.78
OR: 69.57 26.17
AgR: 38589.26 7328.61
Bitswap: 1215155/1215208 50373/50414
09-03-2015 5:03 PM
09-03-2015 7:20 PM
09-03-2015 8:33 PM
Most browsers let you go into a developer tools and then show a graphic of what parts of the page loaded when and how long they took.
For example, in Chrome hit F12 to get into developer tools, ctrl-F5 to reload the page with no cache, then the Network tab will show what was going on.
Looks pretty much the same in IE (except you need to enable the Network tracking as well for it to work).
Might help you track down more precisely what is slowing things down.
10-03-2015 7:00 AM
10-03-2015 9:49 AM
I already tried changing DNS to the Google ones 8.8.8.8 and 8.8.4.4 and didn't make a lot of difference but I'll do more tests.
As to high ping value, that is a factor I appear to have little control over and to be honest when I use Speedtest.net I always get about 21ms and when I use Thinkbroadband original tester or the new one it is always higher and sometimes 40 -50ms.
As I don't do any on-line gaming I've never worried too much about it?
I am awaiting my neighbour to come back from holiday so I can take my laptop and conduct tests on his BT Infinity connection.
Many thanks once again..
Pete
Re: Thankyou folks :) Adverts or PlusNet profiling slowing page loading help?
10-03-2015 10:47 AM
Thankyou so much for everyone who mentioned Adblockers I cannot believe the difference in my browsing experience in Chrome, Firefox AND IE.
I was naïve enough to assume 'opting out' of Google ads and ad choices actually did something
An old dog certainly can learn new tricks...
Regards,
Pete
