Terrible speeds at peak time
JoshHarrison
As the title says I'm currently experiencing terrible speeds at peak. My average speed should sit around 79mb on Fibre and I'm normally getting around 8-12mb download speed.
Please see below:
Gateway:
You are currently connected to gateway pcl-ag04.
This is located in City Lifeline House.
Speedtest:
http://www.speedtest.net/my-result/5700922113
Ping test:
Computing statistics for 75 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0 DESKTOP-AQ7SFC3.lan [192.168.1.73]
0/ 50 = 0% |
1 18ms 0/ 50 = 0% 0/ 50 = 0% dsldevice.lan [192.168.1.254]
0/ 50 = 0% |
2 44ms 0/ 50 = 0% 0/ 50 = 0% lo0-central10.pcl-ag04.plus.net [195.166.128.185]
0/ 50 = 0% |
3 36ms 0/ 50 = 0% 0/ 50 = 0% link-a-central10.pcl-gw01.plus.net [212.159.2.172]
0/ 50 = 0% |
4 35ms 0/ 50 = 0% 0/ 50 = 0% xe-0-2-0.pcl-cr01.plus.net [212.159.0.204]
0/ 50 = 0% |
5 35ms 0/ 50 = 0% 0/ 50 = 0% po2.pcl-gw01.plus.net [195.166.129.41]
0/ 50 = 0% |
6 36ms 0/ 50 = 0% 0/ 50 = 0% cdns01.plus.net [212.159.6.9]
Trace complete.
Any help would be appreciated. Thanks.
Josh
4 REPLIES 4
JoshHarrison
Re: Terrible speeds at peak time
Just to add there's no difference between wired/wireless speeds and this is the line check result:
Postcode:
Phone exchange:
GLENFIELD
Estimated line speed:
80Mb (This may vary between 71.6Mb and 80Mb) - Checked on 2016-07-31 18:15:10
Current line speed:
78 Mb
MrSilver
Fixes: 9
When you get slow speeds what result does the btw Speedtest give you?
JoshHarrison
MrSilver - Thanks for the reply.
Speeds are almost exactly the same as the one shown on speedtest. Between 8-12mb.
JoshHarrison
Just to put things into perspective as to how things can fluctuate.
At the moment I have 2 Alienware Laptops connected to the internet, I'm working on one, my mrs is on the other, I'm also downloading a 50gb file and my speeds are more than acceptable. Circa 50mb d/load.
http://www.speedtest.net/my-result/5702348042
Why is there such a huge fluctuation at peak time?
