Terrible speeds after asus dsl-ac68u
HaydnExport
Hi , my speeds are less than 1/3 of when i rejoined plusnet last march (i think)  due to the asus dsl-ac68u going bonkers and disconnecting randomly.  I've now put back the hg612 and use the asus as just a router , my question is, is there still no way of resetting dlm on my line ? As 24mb when i was getting 70 is a bit poo .  Or seeing as my 12 months is near an end could i just run it down and start afresh with a 'new' 12 month contract and engineers visit?
HaydnExport
Re: Terrible speeds after asus dsl-ac68u
I take it thats a no then?
You'll need to raise a fault if your line is performing lower than your estimates.
(The Asus FTTC modem/router has been a bit of a nightmare for some people).
HaydnExport
apparently asus have found the fix and given us a beta firmware , ill give it one last try and see how it goes.
AArdvark
According to my experience, the only way to get a DLM reset is IF an Openreach Engineer requests it.
This means logging a fault that gets an OR Engineer on-site.
The Engineer can then request a DLM Reset if there is a fault found & fixed.
thunderer
