Technicolor tg589vac cannot connect
FIXED- Subscribe to RSS Feed
- Re: Technicolor tg589vac cannot connect
05-11-2019 11:04 AM
Fixed! Go to the fix.
05-11-2019 11:57 AM
You are correct in that you do not need the OR modem.
Plusnet have never supplied the tg589 so there is no specific guide for it but it should work if configured correctly. Theres a useful guide here https://support.zen.co.uk/kb/Knowledgebase/Technicolor-TG589vac-VDSL-Fibre-Optic-Setup which shows how to configure it on a zen fibre connection.
Follow that but replace the username with youraccountname@plusdsl.net and the password you use to login to the plusnet portal(member centre) as in the article here https://www.plus.net/help/broadband/broadband-connection-settings/
Hope that helps
05-11-2019 12:17 PM
Routed type is set to PPOE and MTU is set at the default option of 1500 and I'm trying to connect on the VDSL option. Not sure if any of this is helpful just throwing it out there in case I'm missing something obvious
05-11-2019 12:24 PM
Have you got the vlan enabled and the Id set to 101 ?
05-11-2019 12:27 PM
05-11-2019 12:33 PM
05-11-2019 12:36 PM - edited 05-11-2019 12:37 PM
That does sound like a userid/ passwordcproblem. I can only suggest you double and triple check those
Edit , glad you got it sorted
