Technicolor TG582n VPN Issue
- Technicolor TG582n VPN Issue
24-09-2015 1:32 PM
I got my work tech support to log on and try it, but they couldn't figure it out. the only thing they found was the error was too vague to pin to a specific issue and by looking at various boards that its a known issue with this router.
it failed using windows 7 & 8 with the plusnet software security firewall off and on , I'm just setting a standard vpn connection and entering my login details.
its definatley not the vpn (works for other people not on plusnet fibre)
just been on chat with plusnet and they dont support advanced networking issues (which I find a bit strange but there you go) and the lady directed here
HELP!!
Re: Technicolor TG582n VPN Issue
28-09-2015 9:34 AM
anyone?
is it worth trying to lay hands on an old BT homehub?
28-09-2015 9:47 AM
There have been some issue with VPN and the TG582n in the past, a lot depends on which version of the frimware you have.
Start by having a read of these threads
http://community.plus.net/forum/index.php/topic,136339.0.html and http://community.plus.net/forum/index.php/topic,102798.0.html
28-09-2015 11:06 AM
if the
connection applist
connection unbind application PPTP port 1723
saveall
doesnt work, what do i do to restore it?
is it just connection applist
connection bind application PPTP port 1723
saveall
or am I being too optomistic?
28-09-2015 3:27 PM
Is your VPN using PPTP or IPSec ?
28-09-2015 6:19 PM
tried bind and it accepted then unbind and it accepted.. looks like it was already unbound
looking at the settings they left, rather than auto they had it on PPTP
28-09-2015 6:35 PM
It was already unbound on some versions of firmware.
Quote looks like it was already unbound
Just going back to this comment earlier...
Quote it failed using windows 7 & 8 with the plusnet software security firewall off and on
Did you disconnect and reconnect your ppp session after making any changes. The changes only take effect after the session is re-established.
28-09-2015 8:35 PM
