Technicolor TG582n VPN Issue
Beancountertoon
I'm having real issues connecting to my work VPN through the above router.
I got my work tech support to log on and try it, but they couldn't figure it out. the only thing they found was the error was too vague to pin to a specific issue and by looking at various boards that its a known issue with this router.
it failed using windows 7 & 8 with the plusnet software security firewall off and on  ,  I'm just setting a standard vpn connection and entering my login details.
its definatley not the vpn (works for other people not on plusnet fibre)
just been on chat with plusnet and they dont support advanced networking issues (which I find a bit strange but there you go) and the lady directed here
HELP!!
Beancountertoon
Re: Technicolor TG582n VPN Issue
bump
anyone?
is it worth trying to lay hands on an old BT homehub?
Fixes: 56
Welcome to the forums,
There have been some issue with VPN and the TG582n in the past, a lot depends on which version of the frimware you have.
Start by having a read of these threads
http://community.plus.net/forum/index.php/topic,136339.0.html and http://community.plus.net/forum/index.php/topic,102798.0.html
Beancountertoon
Cheers, I'll have a bash at that 2nd one tonight
if the
connection applist
connection unbind application PPTP port 1723
saveall
doesnt work, what do i do to restore it?
is it just connection applist
connection bind application PPTP port 1723
saveall
or am I being too optomistic?
Fixes: 56
yes, that sounds right!.
Is your VPN using PPTP or IPSec ?
Beancountertoon
failed to unbind
tried bind and it accepted then unbind and it accepted.. looks like it was already unbound Sad
looking at the settings they left, rather than auto they had it on PPTP
Fixes: 56
It was already unbound on some versions of firmware.
Just going back to this  comment earlier...
Did you disconnect and reconnect your ppp session after making any changes. The changes only take effect after the session is re-established.
Beancountertoon
yeah, multiple retstarts after changes over days..
