Hi apologies if this is not in the correct place in the forum
Can someone help me with port forwarding.
I need someone to remote access a device on my local network. I have set the device up on a static ip address, Setup A game or application is made of one or more TCP/UDP port range. and I know the port required.
I have check remotely that the desired port is open and it is but all they get is error 403
I assume its httpallowed which id denied? but where would I find that on on this particular router?
