Tablet fast, PC slow??
- Tablet fast, PC slow??
- « Previous
- 1
- 2
- Next »
Re: Tablet fast, PC slow??
30-07-2017 8:08 PM
@bobw1943 wrote:
Actually the router is less than 24 inches from the wi-fi adapter, but there is a brick wall between them.
Drill a hole through the wall and use a ethernet cable.
30-07-2017 8:10 PM
12mm should do it
30-07-2017 8:20 PM
If it's a single brick wall you could knock a hole through the mortar large enough for the ethernet plug with a blunt screwdriver.
30-07-2017 8:57 PM
Is the Experian connecting at 5Ghz while the PC is using 2.4Ghz (assuming you have a dual band router).
Check the level of interference (other people's WiFi) on 2.4 GHz.
Get a 5Ghz dongle for the PC.
30-07-2017 9:46 PM
I think this is the solution.
The wall is actually a cavity wall being the old outer wall of the house. My PC is in an extension.
31-07-2017 5:19 PM
Ideally, that's the way forward.
Alternatively, I agree with bmc in that a set of powerline adapters may come in handy in this situation.
- « Previous
- 1
- 2
- Next »
