Tablet fast, PC slow??
bobw1943
Speedtest.net records a speed of 2.7mbps for my PC; when I test with my Experia tablet I get 44.8 mbps.
My PC is on Windows 10 with the latest updates using an Edimax N150 USB adapter.
What steps can I take to find why my PC is so slow.
Fixes: 6
Re: Tablet fast, PC slow??
What's the PC like on a wired connection?
bobw1943
I haven't tried, mainly because of the upheaval involved moving the PC/monitor etc. to another room where the router is. It could be done at a push but I was hoping there might be other things to try.
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules
Fixes: 6
Buy a cheap WiFi dongle to double test the PC or alternatively buy a long Ethernet cable.
Fixes: 4
what speed are you connected at ?
From a command promt type   netsh wlan show interfaces   to see what speed your connected at.
Also look at whats around you http://www.wi-spy.co.uk/index.php/component/content/article/49-inssider-2
Fixes: 6
You could try setting different wireless channels in the router. For wireless n the preferred channels are 1, 6 or 11 -- test each one of those three to see which is best.
You could also try putting the USB wifi adaptor on the end of a long USB cable, try the adaptor in different positions the higher the better..
bobw1943
This is the response to the command line prompt
Fixes: 4
56% Signal isn't great and that is reflected againt the speed which is showing as 20 mbps.
As npr said try moving channels first.
Fixes: 4
@bobw1943 might be worth buying something with an aerial tbh like this one
Fixes: 4
We got one of these when the lad was having problems while away at uni.
bobw1943
Changed channel to AUTO.
Fixes: 4
Not sure how far you expect an Edimax to stretch tbh.
One of these things is it ?
bobw1943
Actually the router is less than 24 inches from the wi-fi adapter, but there is a brick wall between them. You could join them with a piece of string no longer than 8 feet but the route involves an 360 degree corner.
Fixes: 4
Yeah brick walls are bane of the little guy.
Here's mine which is at the back of a chimney upstairs with a good qaulity adapter.
    Description            : Intel(R) Dual Band Wireless-AC 7265
    GUID                   :
    Physical address       :
    State                  : connected
    SSID                   :
    BSSID                  :
    Network type           : Infrastructure
    Radio type             : 802.11n
    Authentication         : WPA2-Personal
    Cipher                 : CCMP
    Connection mode        : Auto Connect
    Channel                : 8
    Receive rate (Mbps)    : 270
    Transmit rate (Mbps)   : 270
    Signal                 : 99%
Fixes: 6
Confirm with an Ethernet cable there's no problem with the connection - it may not look great but at least it would tell you your PC's OK. There doesn't look like there's a problem with your router given your tablet speeds.
It things are working with a wired connection think about Ethernet Powerline adapters.
