TPS
rongtw
Fixes: 12
TPS
TPS i presume most will know what it is ,, Anyhow my number is registered so i dont get marketing calls Thumbs Up
But Economy Energy keep ringing me to swap to them , so i want to complain to TPS ,,, but it keeps timing out Huh
can someone confirm that is not just me http://www.tpsonline.org.uk/tps/index.html  , click make a complaint
Mayfly
Re: TPS
Timed out for me too, but then again a lot connections to various sites are slow for me this morning.
newagetraveller
Re: TPS
Yes, it's just the "make a complaint" that times out for me.
A bit pointless if an individul can't make  complaint. Then again the TPS is a toothless and useless nonentity anyway.
Fixes: 385
Re: TPS
not timing out for me over a VPN.
My Broadband Ping - PN-Fibre
bobminors
Re: TPS
Works okay for me. Probably just the TPS web server being slow.
Fixes: 21
Re: TPS
I've been with TPS for many years, but they are toothless.
The best way of getting rid of spam calls is a call blocker. I bought one about 3 years ago and my spam calls dropped to nearly zero from 5-7 a DAY.
Just about to upgrade to one with an lcd screen so you can block a call you missed or answered on an extension. That is the only PITA with it you have to press a button to block the call when it is live (or enter a long string of numbers to block it afterwards) and can't block from an extension, I believe the newer ones have this facility though. But I am getting a cheap Chinese one rather than the £50 UK one.
Fixes: 71
Re: TPS
It works OK for me too using a standard fibre connection.
David
rongtw
Fixes: 12
Re: TPS
must have been their problem ,, it works now Thumbs Up yet i try yesterday and this morning with no joy
St3
Aspiring Champion
Fixes: 5
Re: TPS
I seen somthing on tv a few months ago regarding tps and cold callers, and from what i seen if a company calls you from outside the uk then tps cant stop them. TPS are only able to block those who call from inside the uk and maybe this how you are getting calls still.
vultura
Re: TPS
I have a feeling you are correct and that TPS can only deal with UK based callers.
For some tips on cold calls try - http://www.which.co.uk/reviews/nuisance-calls/article/ten-tips-to-stop-cold-calls
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Has anyone seen my signature, it's gone missing.
