TP Link VR900 wont reconnect after power cut.
- TP Link VR900 wont reconnect after power cut.
Re: TP Link VR900 wont reconnect after power cut.
24-12-2015 11:17 AM
24-12-2015 11:37 AM
Quote from: Bob I was asking about the VR900 hardware version (see attached). Is that V1 or V2?
Version 1
One thing i have set up with my router is a reserve address in the LAN settings for my desktop pc, is it possible that this is causing the modem to lose sync due to a bug not addressed by the firmware?
26-12-2015 12:39 PM
System log is showing a notice of No ip addresses to give, OFFER abandoned and then Recv DISCOVER from XX:XX:XX:XX:65:86 (replaced XX for Mac address). I am seeing some Errors(pkts) on Upsteam low hundreds, zero on Downsteam. I tried all firmware the beta firmware seems the best for lower Errors(pkts) on Upsteam.
E-mail TP-Link support and supplied them with systems logs and screen dumps of router status page, still waiting to hear back from them what is happening.
I may send it back to Amazon if I still seeing problems , I have until the end of Jan 2016.
If someone from PlusNet support can check my line is working ok that would be great
Cheers
Simon
29-12-2015 3:02 PM
30-12-2015 6:00 PM
My user name is duncums
Simon
30-12-2015 6:15 PM
Session Started Session Ended Session Duration
15:15 30/Dec/2015 N/A 2:57:25 (on going)
15:12 30/Dec/2015 15:15 30/Dec/2015 0:3:1
20:49 29/Dec/2015 15:04 30/Dec/2015 18:14:55
15:11 28/Dec/2015 20:48 29/Dec/2015 One Day, 5:37:17
14:23 28/Dec/2015 15:10 28/Dec/2015 0:47:0
02:30 28/Dec/2015 14:23 28/Dec/2015 11:52:44
10:26 27/Dec/2015 02:30 28/Dec/2015 16:3:44
17:10 25/Dec/2015 10:24 27/Dec/2015 One Day, 17:14:1
16:36 24/Dec/2015 17:10 25/Dec/2015 One Day, 0:33:49
22:55 16/Dec/2015 16:34 24/Dec/2015 7 Days, 17:38:32
22:20 16/Dec/2015 22:55 16/Dec/2015 0:35:7
22:18 16/Dec/2015 22:19 16/Dec/2015 0:0:39
12:09 16/Dec/2015 22:15 16/Dec/2015 10:5:38
08:31 15/Dec/2015 12:08 16/Dec/2015 One Day, 3:36:24
The TP-Link logs you referred to sound like DHCP notices rather than something at the PPP connection layer?
30-12-2015 8:23 PM
I found that VR900 router did not like the Apple Time capsule (3rd gen) and had a problem on holding the IP address seems to keep losing. It and also had a problem of losing the internet ( on my MacBook's and desktop PC. But both MacBook's reported a strong WiFi signal when the internet went down and PC was still showing a LAN connection.
I decided to return the unit as I could get a full refund and gone back to my PlusNet router with the Apple Time capsule.
31-12-2015 8:39 AM
04-01-2016 7:06 AM
09-01-2016 3:05 PM
So thought would update firmware to the latest one recently released ....installed no problem and connected first time .
Will see how it goes with this firmware .
09-01-2016 9:14 PM
Reason i ask is that some of these variables on your connection could be why its more stable on your fibre connection, id be surprised if its the same set up as mine. Thats why i mentioned the issues some ppl were having with the modem in the Asus DSL68U (Broadcom chipset) as its suspected those differences is why it was more stable for some & not for others
09-01-2016 10:17 PM
No idea what cabinet I'm on… is there a way of finding out ?
09-01-2016 10:48 PM
mav:quote
09-01-2016 11:22 PM
10-01-2016 12:09 AM
