TP Link VR900 wont reconnect after power cut.
- Re: TP Link VR900 wont reconnect after power cut.
- « Previous
- Next »
10-01-2016 12:21 AM
10-01-2016 12:38 AM
That perhaps would explain why its more stable for you?
Im on a Huawei 288 FTTC cabinet so my DSLAM is a Huawei MA5603T - Broadcom chipset, which is why i find it odd its unstable for me since it should be more compatible with the Broadcom chipset in the TP Link router? but then that might not be the root cause, it could be whether your on Fastpath or Interleave with G.INP enabled, i do not know which i am on as my line stats dont say but i have recently found out G.INP is enabled on my line
10-01-2016 12:41 AM
Might be worth sending this info to tp-link to see if helps them find a fix .
12-01-2016 9:02 AM
Quote from: shylok ECI 128/256 FTTC cabinet, so the DSLAM is an ECI M41 - Lantiq chipset
That perhaps would explain why it's more stable for you?
As mentioned here, I'm on a Huawei cab and I don't suffer from drop outs
12-01-2016 11:15 AM
12-01-2016 11:52 AM
i do not know what mine is, perhaps a Plusnet rep could tell me? if im on the same connection as Bob then that would be interesting, also other variables include the quality of the connection (Line Attenuation / SNR Margin / distance, etc) which all play a part.
Currently DLM i suspect is capping my speed due to switching off the router modem one too many times so noise margins have risen last time i checked. Now im back to using the ECI modem & put the TP Link in wifi mode to try & stabilise it. I'll be returning the router back to Box in 2 weeks if i don't receive a firmware fix, their tech support have gone quiet on me.
12-01-2016 1:44 PM
Quote from: shylok ... perhaps a Plusnet rep could tell me?
You have G.INP enabled both down and upstream by the looks of things and you're on a 54/17 profile:
0.128M-54M Downstream, Retransmission High - 0.128M-17M Upstream, Retransmission Low
I have a lower level of G.INP protection on my downstream, but I'm fastpath/uninterleaved on the up. I'm also on the max profile:
0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
12-01-2016 4:04 PM
I am on a Huawei cab with an HG612 modem, and used to have G.Inp enabled on both US and DS. Now only on DS.
Do we know why some people have it on US and others don't? (I am talking about people on Huawei cabinets and with compatible modems)
Thanks.
12-01-2016 4:10 PM
Quote Upstream
Initially, fast mode is applied by default on all lines. 90% of lines stay in this mode and never move. If the line is experiencing trouble in the upstream then DLM will enable retransmission at the low level.
12-01-2016 4:29 PM
12-01-2016 5:09 PM
12-01-2016 5:47 PM
Presumably if there were enough errors on my upstream, I would come off fast path, and G.Inp would become active?
14-01-2016 10:35 PM
Be connected since without any issues.... still have pkt errors so thats not changed lol
22-01-2016 4:51 PM
- « Previous
- Next »
