TP Link VR900 or Billion router?
- TP Link VR900 or Billion router?
10-09-2015 5:03 PM
Re: TP Link VR900 or Billion router?
10-09-2015 5:33 PM
However are you sure that it was the router which lost connection to the modem rather than the modem losing connection
10-09-2015 6:03 PM
10-09-2015 6:03 PM
10-09-2015 6:10 PM
10-09-2015 6:10 PM
10-09-2015 6:30 PM
10-09-2015 9:02 PM
I have tried the 8800axl and the WiFi duel band was easy to set up , my wife's laptop used 2.4g and my tablet and phone 5g,setting up your own password is straight forward
10-09-2015 9:23 PM
10-09-2015 9:35 PM
10-09-2015 9:50 PM
My recommendation is to go into the router interface and click on disconnect then leave it for a couple of minutes then pull the power lead out of the modem rather than disconnecting it from the phone socket
The theory behind the last bit is that the modem sends a dying gasp signal when the power fails and then it isn't seen as a line problem by the dynamic line management system
10-09-2015 10:12 PM
11-09-2015 8:49 AM
Your HH4 can still be used with Fibre , see here http://community.plus.net/forum/index.php/topic,135840.0.html
Quote I was using a BT home hub 4 before I upgraded to fibre
11-09-2015 9:25 AM
12-09-2015 10:09 AM
I used to like Billion but they may have gone downhill recently. The last Billion I had - the 8800NL - was awful. Constant crashes. Even its reset button was missing - you went to press it and your pin went straight into the innards of the device. Not good.
I would go for TP-Link, Asus or AVM. Definitely stay away from the BT Home Hub.
