TP-Link VR600 unable to access internet (fibre)
jmroderick
I've just signed up to Plusnet and, while the Hub One seems to work fine, I'd like to use my TP-Link VR600 router instead.
After following the fibre-specific instructions listed at https://www.plus.net/help/broadband/broadband-connection-settings/
I'm unable to get to the internet but I do get redirected to the BT Wholesale page at 62.6.38.125
Anyone used a VR600 successfully with Plusnet broadband?  What am I missing?  Thanks in advance.
2 REPLIES 2
jmroderick
Re: TP-Link VR600 unable to access internet (fibre)
Sorted Smiley
Thanks to https://flowerbunch.org.uk/how-to%E2%80%A6-plusnet-fibre-broadband-with-tp-link-archer-vr600-router
The key seemed to be selecting 'Other' in provider and then specifying the password (even though it looks as though it's picked up the setting already).
Plusnet Alumni (retired) OskarPapa
Fixes: 63
Thanks for posting your experience @jmroderick, we really appreciate it.
With any luck, any others experiencing this issue will find this post and be able to resolve it as quickly as you have!
Please let us know if there's anything you need help with.
