TP Link TD-W9980 VDSL
- Re: TP Link TD-W9980 VDSL
07-07-2015 9:10 AM
TP-LINK TD-W9980 N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router (2.4 GHz 300Mbps, 5 GHz 300Mbps, 2 USB Ports for Storage Sharing, Media/Print Server)
My question is this,i have a new phone socket on the wall with the BT modem plugged into the bottom half & my phone plugged into the the top half.
Once i remove the PN router & BT modem do i need to to fit a filter for my new setup or does the new TP Link plug into the bottom half of the socket where the BT modem is just now,hope that all makes sense
07-07-2015 9:26 AM
Nice router too!
07-07-2015 9:40 AM
07-07-2015 9:41 AM
07-07-2015 10:22 AM
07-07-2015 2:23 PM
07-07-2015 2:41 PM
07-07-2015 8:51 PM
MisterW is right the latest firmware does have plusnet as an option so you just need to select that and type your plusnet username and password then you are good to go;)
07-07-2015 9:34 PM
07-07-2015 11:40 PM
I would probably download it first anyway.
Connect the router directly to a PC via Ethernet, but not connected to the phone socket.
Login, check the firmware version and update if necessary.
Then set up the router, power down and connect it all up.
That is what I did.
08-07-2015 12:03 AM
Which doesn't matter until you perhaps come to install your new VDSL2 router and plug it into the bottom socket. First the socket and plug will be different sizes, though I believe the plug will fit and maybe even work, but second, it won't work because there is no VDSL2 signal on the bottom socket.
Re updating the firmware before using it to connect, if yours isn't up to date then download the update to your computer and install it offline to the TP-Link.
08-07-2015 9:14 AM
08-07-2015 9:17 AM
Thank you,will try that when it arrives.
Quote from: Wavemachine You have to download the firmware to a PC first before you can update the firmware, I don't believe you can update it directly from the Internet.
That is what I did.
08-07-2015 9:26 AM
TD-W9980_V1_140925
Publish Date
25/09/14
Language
English
File Size
7.65 MB
Modifications and Bug Fixes
Updated the drive of wireless 5GHz.Solved the 5GHz wireless channel problem when choosing Taiwan as reigon.
Updated DSL firmware,fixed the problem of ADSL low synchronization speed in Turkey.
Notes
For TD-W9980(UN)_V1
08-07-2015 9:39 AM
here
Bug Fixed:
1.Fixed the bug that the speed dropped on the BT line of UK when G.INP was enabled.
That's the important bug fix for us.
