TP-Link TD-W9980 - Router Crashing
nimdy
Hi all. I bought a TD-W9980 from Amazon a few months ago. All seemed fine for a while but recently it started to drop its WiFi connection. When this happens the wired connections are maintained (i have a small media centre PC connected via ethernet) so the internet connection itself is being maintained. The only fix seems to be to restart the router. I contacted Amazon to get a replacement as I believed it to be faulty. The new one has the same fault. I know I can't complain to Plusnet as I have bought a 3rd party router, but I was wondering if anyone here on the forums has the same model and problems, or knows if there is anything I can do to fix it. Or can anyone recommend a rock-solid but cost effective router?
Fixes: 20
Re: TP-Link TD-W9980 - Router Crashing
Strange been using that same router for nearly a year and not had that issue.
Try a factory reset and then setup everything again (DON'T RESTORE the settings just incase they contain the problem)
Fixes: 55
Not the only one with the problem apparently http://forum.tp-link.com/showthread.php?83820-W9980-WiFi-drop-out
Not sure if trying changing the wifi channel ( and disabling auto-detect? ) might be useful...
Fixes: 20
Do you know if both the 2.4 GHz and the 5 GHz wireless networks are affected? Or is it only one of them? They should be entirely separate, if one breaks, the other should continue working.
