TP Link Archer D5 v1
bubblegum57
Hi, I was having a few problems with wifi in the bedrooms (HUB one) so I bought a TP link TD W9880, this setup pretty easily.
Then I saw a TP link Archer D5 v1 for a few pence more, I bought this, updated the firmware, but when I went through the wizard selecting Plusnet, the settings wanted
VCI/VPI  0,38
below, is what I need for Plusnet Fibre
Broadband Username/Login name username@plusdsl.net
Connection Type / Encapsulation PPPoE Always On
VLAN Active
802.1p 0
802.1q 101
Is there any way to use/setup the Archer for Plusnet Fibre?
Fixes: 36
Re: TP Link Archer D5 v1
The Archer D5 is an ADSL2 router, not a VDSL router, so won't work directly on your fibre connection. the W9880 is a VDSL router.
bubblegum57
Thats what I was beginning to realise.
Thanks for the confirmation
Smiley
Fixes: 65
Do you still have the 9980 or did you swap it for the D5 ? I THINK it might be possible to use the 9980 as a VDSL modem
bubblegum57
Yes, I kept the 9880 & it works ok. I found the archer & because it was ac & only a few pence more, I ordered it.
Still have 3 weeks to return the 9880. I will have to return the archer.
Fixes: 65
Ok, I understand now. I was thinking if you had to keep both...
