TP-Link AC1900 Archer VR900 unable to connect to internet!
- Re: TP-Link AC1900 Archer VR900 unable to connect ...
01-12-2015 1:44 PM
Selected PlusnetVDSL
Ive entered username@plusdsl.net
password
PPPoE
checked connections
No IP Address detected
No Default Gateway
No Primary or Secondary DNS
Fails xDSL Synchronisation
Reconnect to previous setup - all is running normally
Any suggestions would be appreciated
Ian
Re: TP-Link AC1900 Archer VR900 unable to connect to internet!
01-12-2015 5:12 PM
That sounds pretty basic, it's not seeing a VDSL signal. You are connected directly from the DSL port on the VR900 to where the Openreach Modem was connected to the phone line ?
Quote Fails xDSL Synchronisation
01-12-2015 5:16 PM
Ian
01-12-2015 5:43 PM
01-12-2015 5:47 PM
Prior to recieving the service i invested in a CAT6 lead for the socket to modem and are using that with no problems - ill try the included TP cable tomorrow.
Thanks again for your interest
Ian
01-12-2015 5:51 PM
but that's got RJ45 ( 8 pin ) connectors. Surely the DSL port is an RJ11 ( 4 pin ) ?
Quote Prior to recieving the service i invested in a CAT6 lead
01-12-2015 6:11 PM
http://www.ebay.co.uk/itm/351230438268?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
That works pefectly with the Openreach Modem
Ian
01-12-2015 6:29 PM
OR I may be barking up the wrong tree entirely. I don't have fibre myself but experience with ADSL is that if the connection is intact then there's little that will prevent a basic sync.
01-12-2015 7:28 PM
Ill try the TL lead in the morning and report back.
Thanks again for your assistance.
Ian
02-12-2015 12:07 PM
02-12-2015 2:59 PM
I have contacted TP and await their response!
Ian
02-12-2015 3:05 PM
02-12-2015 3:10 PM
It could, of course, be a faulty unit
Quote I have contacted TP and await their response!
02-12-2015 3:53 PM
02-12-2015 4:42 PM
