TP Link AC 1900 Touch P5 Router
- TP Link AC 1900 Touch P5 Router
17-12-2015 9:35 AM
I am looking at purchasing the TP Link AC 1900 Touch P5 Modem but being a bit (or a lot) of a newbie am not sure if this can replace my existing modem and router or if I still
need the modem to plug into it.
I wish to have an all in one modem/router to increase my poor signal so would be grateful if anyone has any info on this or can suggest an equal or better unit.
http://www.tp-link.com/en/products/details/cat-9_Touch-P5.html
Many thanks in advance.
Ivan
Re: TP Link AC 1900 Touch P5 Router
17-12-2015 9:49 AM
http://www.amazon.co.uk/gp/aw/d/B00K6D2ESM/ref=mp_s_a_1_5?qid=1450345617&sr=8-5&pi=AC_SX110_SY165&ke...
http://www.amazon.co.uk/gp/aw/d/B00O27PHGY/ref=mp_s_a_1_6?qid=1450345617&sr=8-6&pi=AC_SX110_SY165&ke...
http://www.amazon.co.uk/gp/aw/d/B00GORC5WO/ref=mp_s_a_1_16?qid=1450345648&sr=8-16&pi=SY200_QL40&keyw...
these are all run by many users on the forum and will work, hope this helps
17-12-2015 10:04 AM
I run the slightly cheaper TP-Link W9980 and it does the job if you find the right place to sit it - http://www.amazon.co.uk/TP-LINK-TD-W9980-Wireless-Gigabit-300Mbps/dp/B00NEQZ12Y/ref=sr_1_1?ie=UTF8&q...
Tony
17-12-2015 10:07 AM
17-12-2015 2:39 PM
http://www.amazon.co.uk/TP-LINK-Archer-VR900-Beamforming-Technology/dp/B01132GCP0/ref=sr_1_11?ie=UTF...
17-12-2015 3:11 PM
17-12-2015 3:24 PM
It's annoying how Amazon lump reviews together for a multi option sale entry.
17-12-2015 4:07 PM
Quote 28 and mostly for the N600
As Strat says, mainly for the 600.
See the thread below, start at reply #15 for a definitive opinion.
http://community.plus.net/forum/index.php/topic,146780.0.html
17-12-2015 5:51 PM
Quote from: Strat
If you scroll to the end of he Amazon reviews then
a) click to see all the review
b) scroll back to the top and hit the All Formats button ... then you can select review only for you model you selected ...
17-12-2015 9:27 PM
17-12-2015 10:42 PM
Have decided against the Touch P5 because it needs a separate modem and have decided to go for the Archer VR900.
Ivan
18-12-2015 5:48 AM
Quote and have decided to go for the Archer VR900.
Please let me know how you get on Ivan, I'm very close to buying one for myself.
18-12-2015 11:09 AM
18-12-2015 12:44 PM
18-12-2015 12:59 PM
