TP Link AC 1900 Touch P5 Router
swinburneivan
Hi
I am looking at purchasing the TP Link AC 1900 Touch P5 Modem but being a bit (or a lot) of a newbie am not sure if this can replace my existing modem and router or if I still
need the modem to plug into it.
I wish to have an all in one modem/router to increase my poor signal so would be grateful if anyone has any info on this or can suggest an equal or better unit.
http://www.tp-link.com/en/products/details/cat-9_Touch-P5.html
Many thanks in advance.
Ivan
32 REPLIES 32
khile
Re: TP Link AC 1900 Touch P5 Router
wayyoung
I run the slightly cheaper TP-Link W9980 and it does the job if you find the right place to sit it - http://www.amazon.co.uk/TP-LINK-TD-W9980-Wireless-Gigabit-300Mbps/dp/B00NEQZ12Y/ref=sr_1_1?ie=UTF8&q...
Tony
w23
Fixes: 4
The 'Touch P5' does not have a modem but can be used on FTTC with the existing BT supplied modem.
Call me 'w23'
tijara33
Fixes: 6
Why not buy the excellent TP-LINK Archer VR 900 AC? It does everything you want at £125.12 & comes highly recommended by 1 of the senior PN staff members!! Smiley
http://www.amazon.co.uk/TP-LINK-Archer-VR900-Beamforming-Technology/dp/B01132GCP0/ref=sr_1_11?ie=UTF...
Mal08
Just looked at the on Amazon - and although it has many good reviews it has many 1 stars too ?
Strat
Fixes: 565
28 and mostly for the N600.
It's annoying how Amazon lump reviews together for a multi option sale entry.
tijara33
Fixes: 6
As Strat says, mainly for the 600.
See the thread below, start at reply #15 for a definitive opinion.  Smiley Smiley
http://community.plus.net/forum/index.php/topic,146780.0.html
irritablegit
Quote from: Strat
If you scroll to the end of he Amazon reviews then
a) click to see all the review
b) scroll back to the top and hit the All Formats button ... then you can select review only for you model you selected ...  Wink
Strat
Fixes: 565
Thanks for that irritablegit Smiley
swinburneivan
Many thanks to all that have replied and for all your help.
Have decided against the Touch P5 because it needs a separate modem and have decided to go for the Archer VR900.
Ivan
tijara33
Fixes: 6
Please let me know how you get on Ivan, I'm very close to buying one for myself. Smiley
Fixes: 395
Has anyone looked at the VR200 http://www.tplink.com/be/products/details/?model=Archer+VR200#spec £76 as opposed to £126 and from what I can see the only difference is AC750 Wifi rather than AC1900...
tijara33
Fixes: 6
I am favouring the 1900 because of the increased Wifi speed.  Smiley
Fixes: 395
but unless you're using wifi for access between machines on your local network, are you really going to notice any difference when your internet connection is only 80Mb max ?
