TP-LINK TD-W9980 N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router
gravydavey
Hi All
ive just purchased a TP-LINK TD-W9980 N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router to replace my TG582 and BT openreach. do i need any settings from the TG582 to configure on my new TP link. if so how do i get them.
im presuming a username and password must be embedded in the TG582 along with the settings
Fixes: 62
Re: TP-LINK TD-W9980 N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router
Den1
Yep just your log in details make sure the VPI/VCI is set to 101  Wink  it's a good idea to update the firmware as well, fixes speed issues on some lines.
PasPer2
Keep us updated on the router. I'm thinking of ditching my TG582 in the near future.
gravydavey
will do, arrives sometime this week so hopefully it does the biz
biggles001
I agree with Den 1,changed to the TP-link 9980 a couple of weeks ago,no need to update,it was already on latest s/w,only username and password to be entered.Most impressed,no more BT modem,and decent wireless!
gravydavey
Biggles
how good is the wifi signal in your opinion. at present im using the crappy TG582 and i can pickup my neighbours sky router 2 doors away from my bedroom but cant get the TG582 from downstairs its abysmal
mav:quote
Fixes: 20
I've been using the TPlink for over a year now. With the tg582 I couldn't even get a working signal IN THE NEXT ROOM. With the TP-link I have no issues anywhere inside the house.
Latest f/w just needs you to select PN as the isp and put the user/password in, it sets up everything else, the VC change was only needed before the new f/w.
