TP-LINK TD-W9970 Compatability with Plusnet
- TP-LINK TD-W9970 Compatability with Plusnet
04-06-2020 9:58 PM
I have just bought, from that well-known online market, a new (allegedly) W9970 (Version 1).
The "Quick Installation" was anything but, and, at the end of the day, I could not connect to Plusnet.
All manner of ISPs were shown on the set-up list (including a "Helicopter"!), but NOT Plusnet.
I am wondering whether this is a question of compatibility, or if it was something I did (or didn't do).
Any advice gratefully received.
Re: TP-LINK TD-W9970 Compatability with Plusnet
04-06-2020 10:39 PM
Do you have the full manual?
If not you can download it here: https://setuprouter.com/router/tp-link/td-w9970/manual-2212.pdf
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
04-06-2020 10:48 PM
No I don't...!
Thanks very much.
04-06-2020 10:49 PM
Did it have any UK ISP's listed like BT, EE, talk Talk etc? does it have a UK choice in the country to be used?
Setup guide here: https://wiki.kitz.co.uk/index.php/TD-W9980_QuickSetup
You might be able to perform a factory reset and see if that restores anything.
04-06-2020 10:51 PM
Setup guide here:
Perform a factory reset and start again, make sure you choose UK , perhaps it thinks it's being used in another country.
04-06-2020 10:53 PM - edited 04-06-2020 10:56 PM
04-06-2020 10:56 PM
04-06-2020 11:37 PM
Thanks.
I'll give that a go.
The only reason I bought the TP was because I read that it was better than the Plusnet router, but that's probably the subject of another Post...!
05-06-2020 6:49 PM
Sorry about all the duplicate posts, apparently the site's spam filter kept deleting my posts, let them brew for a day then just released them all together.....I can't delete them either.
