TN13 fibre fault?
Adejordan
TN13 fibre fault?
The connection has been up and down every few minutes since early evening. Hub reboots / power off for a while hasn’t helped.  Status page says all ok - anyone else experiencing problems this evening?
1 REPLY
rongtw
Fixes: 12
Re: TN13 fibre fault?
Best place to check for outages etc https://status.zen.co.uk/broadband/
look for your telephone code
