TG582n web access fail
- TG582n web access fail
20-12-2014 10:52 AM
I have a FTTC connection with the wonderful TG582n wireless router. However I can no longer get web access to it. When I restart it I get access for a while then it stops - I cannot Telnet to it either.
Is this router broken or is there something I can do?
Eserim
Re: TG582n web access fail
20-12-2014 11:25 AM
It sounds like there might be an issue.
Give a <a href="http://www.plus.net/support/broadband/hardware/technicolor-582n-faqs.shtml#factoryReset">factory reset</a> a try please and let drop us a reply if that doesn't clear the issue for you.
20-12-2014 11:35 AM
dick:quote
31-01-2015 2:09 PM
02-02-2015 10:44 AM
03-02-2015 10:02 AM
03-02-2015 3:02 PM
03-02-2015 3:19 PM
04-02-2015 9:09 AM
04-02-2015 10:45 AM
Then yesterday I was getting timeouts on selected sites (eBay images, MSN, Some Plus Net Code)
And now, when I re-loaded my saved setting that point to the OpenDNS servers it fails to even connect to them.
TBH - if Plus Net just gave 2 months free connection and told us to buy our own it would be much better.
04-02-2015 3:12 PM
