TG582n FTTC Router Problem?
- TG582n FTTC Router Problem?
27-11-2015 10:20 PM
Trying to login onto the router I sometimes got a "500 Internal Server Error" or invalid password. If I did manage to get in, it wasn't long before I got the server error again or it just logged me off. For over an hour it failed to get an internet connection (no light). Power cycling didn't make any difference. The broadband, ethernet lights were showing as ok.
It's running alright now but I'm wondering if my router is faulty. Any ideas anyone?
Re: TG582n FTTC Router Problem?
02-12-2015 8:05 AM
04-12-2015 8:42 PM
05-12-2015 2:14 PM
05-12-2015 2:25 PM
I think you can do it from the Member centre but not sure...
05-12-2015 2:30 PM
Edit: I couldn't find it in the Member Centre so have raised a separate post as I don't want to hijack Sparkz' thread, particularly if they don't need/want my router!
05-12-2015 2:54 PM
Quote from: MJN I did wonder about that. Will have a look in the member centre now... Thanks.
Thanks @MJN. Sent you a PM.
05-12-2015 3:01 PM
05-12-2015 9:44 PM
in work we bought a cheap tp-link one from argos for £14.99 solved a host of problems, and as a plus it has guest wireless support and a usb port that allows a backup 3g modem, if needed
