Sync v IP profile wrong
- Sync v IP profile wrong
3 weeks ago
Maximum data rate 24.049 Mbps / 81.569 Mbps
Data rate 20 Mbps / 67.474 Mbps
Bt speed test results.
Download speed achieved 62.23 Mbps
IP Profile 65.31 Mbps
Upload speed achieved 20.60 Mbps
IP Profile 20 Mbps
Something isn't quite right. Is it a stuck profile, miss match something needs sorted at BTs end.
Whats the point in paying for 80Mb and only getting 67Mb.
Re: Sync v IP profile wrong
3 weeks ago
You are not paying for 80. you are paying for up to 80.
The closer you are to the cabinet, the nearer to 80 you will get.
Looks ok to me. Is this the first time you have looked at these stats?
3 weeks ago
3 weeks ago - last edited 3 weeks ago
@maddog56 I've looked at it and as your IP profile is 65.31 Mbps you are not syncing at 80Mbps. I see your modem sync speed is 67.474 Mbps. @Mustrum is perfectly correct. you are paying for up to 80Mbps. You can ignore the maximum data rate figures, they don't mean much as they are just optimistic values calculated by the modem, nothing to do with actual speeds.
2 weeks ago
Just a quick question i have compared why is the snr always around 6db when will it drop to 3db, in the past it has been 3db but after we had a thunderstorm its never went back down, surely this will affect my speeds.
2 weeks ago
@maddog56 there's nothing wrong that I can see with your speeds. Your router's in sync at 67448 so an IP profile of 65.31mbps is correct as the IP profile should be around 96% of your sync speed. Lower if there's interleaving or retransmission enabled on your line by the dynamic line management (DLM) at the cabinet.
There is interleaving in a low state: Downstream: 0.128M-80M with Interleaving (Low). Upstream: 0.128M-20M with no error protection. We can't do anything to adjust the DLM settings, we can just request a reset if your line's banded but the aforementioned profile shows there's no banding.
0.128M-80M means that your line can sync at a speed of between 0.128mbps and 80mbps with no artificial restrictions. The estimated speed of your line is between 55mbps and 73mbps so you're well within expectations and as such our suppliers wouldn't accept a fault report for an engineer to investigate this.
With regards to reducing the SNRM target back down to 3dB this is controlled by DLM as this is a DLM setting but again we don't have any influence over this I'm afraid unlike ADSL connection where we have more control.
I hope this helps.
