Sync speed issues, from 65000/25000 (ish) to 5000/5000 more or less.
- Sync speed issues, from 65000/25000 (ish) to 5000/...
29-01-2016 12:24 PM
Please look into my sync issues:
For the last few days i have had issues where my connection drops briefly and syncs at back at poor speeds; The first time this happened it resynced back up to speed; however, today at 7.40 am (i ping from work) we dropped and i'm back at 5 meg speeds.
This seems to have been fine for nearly 18months prior to this, but i don't monitor my connection all the time.
I have some information that may diagnose things sooner here, thanks:
Type: VDSL2
Hardware: Annex A
Firmware: 05-07-04-03-00-07
Power Mngt Mode: DSL_G997_PMS_L0
Line State: SHOWTIME
Running Mode: 17A
Vendor ID: b5004946 544e0000
ATU-C Information
Vendor ID: b5004244 434da459 [BDCM]
Line Statistics
Downstream Upstream
Actual Rate 7051 Kbps 4976 Kbps
Attainable Rate 7089 Kbps 5047 Kbps
Path Mode Fast Fast
Interleave Depth 1 1
Actual PSD 6. 4 dB 10. 5 dB
Near End Far End
Trellis ON ON
Bitswap ON ON
ReTx 1 1
SNR Margin 6 dB 6 dB
Attenuation 32 dB 47 dB
CRC 4 4677
FECS 0 s 1380 s
ES 3 s 4070 s
SES 1 s 15 s
LOSS 0 s 0 s
UAS 26 s 2591 s
HEC Errors 0 0
RS Corrections 0 0
LOS Failure 0 0
LOF Failure 0 0
LPR Failure 0 0
NCD Failure 0 0
LCD Failure 0 0
NFEC 32 32
RFEC 16 16
LYSMB 16 16
Please look into this an advise.
Kind regards,
Bailz.
Hardware: Annex A
Running Mode: 17A
ATU-C Information
Line Statistics
Downstream Upstream
Path Mode Fast Fast
Near End Far End
Trellis ON ON
Bitswap ON ON
ReTx 1 1
CRC 4 4677
FECS 0 s 1380 s
ES 3 s 4070 s
SES 1 s 15 s
LOSS 0 s 0 s
UAS 26 s 2591 s
HEC Errors 0 0
RS Corrections 0 0
LOS Failure 0 0
LOF Failure 0 0
LPR Failure 0 0
NCD Failure 0 0
LCD Failure 0 0
NFEC 32 32
RFEC 16 16
LYSMB 16 16
Kind regards,
Bailz.
Message 1 of 5
(935 Views)
4 REPLIES 4
Re: Sync speed issues, from 65000/25000 (ish) to 5000/5000 more or less.
29-01-2016 12:25 PM
Message 2 of 5
(503 Views)
29-01-2016 12:35 PM
Thanks.
I can provide all the connection details necessary if there's anything else that needs looking at.
Thanks again.
Thanks again.
Message 3 of 5
(503 Views)
29-01-2016 1:18 PM
Message 4 of 5
(503 Views)
29-01-2016 2:46 PM
Just for the records: My connection rebooted around 2PM and now syncs normally.
This might be due to work done on it, if not, will post again as there may be something going on with the line itself.
Thanks for your help so far.
Actual Rate 67226 Kbps 19999 Kbps
Attainable Rate 67238 Kbps 27477 Kbps
Path Mode Fast Fast
Actual PSD 6. 9 dB 13. 1 dB
Near End Far End
Trellis ON ON
Bitswap ON ON
ReTx 1 1
SNR Margin 5 dB 9 dB
Attenuation 14 dB 16 dB
Message 5 of 5
(503 Views)
