Sync speed increses and IP profile thru put goes down
g3uiss
Last night I went at last to Fast Path. My Sync speed has increased by 4MB, and I have normal ping 14ms to BBC. My IP Profile reported by BTW test is now 24.2MB (previous 20.1) However my speed test results have gone down from a norm of about 19.5Mb to 18.95. Surely I should see some improvement no a degradation. Upload has increased in line with improved sync rate. I have tried Gateway Hopping. Nothing changed, even a token reboot of the router ?
Tony
Re: Sync speed increses and IP profile thru put goes down
What's your Current Line Speed here https://portal.plus.net/my.html?action=data_transfer_speed ?
g3uiss
24.50 Tony
Have you tried some other speed testers?
Can you double-check the BT IP profile and the Plusnet Current line speed?
The PN one should always be lower (normally 0.1-0.2 Mb/s lower) than the BT one, in some circumstances having the PN one higher could cause some packet loss.
Also the higher sync with no interleaving may be causing more (CRC) errors (in which case DLM may intervene again and re-apply interleaving).
Call me 'w23'
g3uiss
No the PN is slightly lower also I have had virtually no CRC errors since the DLM intervened this morning at 0350. I have now spoken to support and they seem to think the line might be capped at the Old Sync speed Huh
Also referring to previous post ....yes tried several all very similar
See BTW speed test just taken
Tony
g3uiss
I'm sure PlusNet have my profile capped at the old IP profile / sync speed. Hoping one of the Digital Care Team will pick this up for me
Tony
Fixes: 167
The latest BT speedtest is showing that your IP profile is 23.87Mbps. The profile on our side (the link AndyH provided) is showing as 20100, I can't see that it's been 24.50 previously.
I've updated the profile on our side to match the BT one now, can you log in to the router and try a single disconnect/reconnect and hopefully you should see an improvement in speed
 Chris Parr
 Plusnet Staff
g3uiss
Chris
Thanks, speed has come right up now. (The speed I reported was Sync not IP profile, that I got from my line stats). Its now all back to where I was before I got interleaved by the DLM. Its showing exactly what I would expect on your site link.
Will you cancel the "Ticket" or should I just close it ?
Thanks for your help Tony
Fixes: 167
Feel free to just close the ticket. Glad to hear this is back to normal.
 Chris Parr
 Plusnet Staff
