Sync speed halved overnight after modem restart - stabilisation?
- Sync speed halved overnight after modem restart - ...
a month ago - last edited a month ago
Yesterday evening I was rearranging stuff and had to restart my modem a couple of times. When it reconnected it was fine, syncing at 56 Mbps as it has done utterly solidly for 7 years.
When I woke up this morning the sync speed was 28 Mbps. I have reconnected a couple more times but it has stuck at this speed all day so far.
Have I just triggered a stabilisation period do you think and it will sort itself out, or do I need to contact Plusnet to get them investigating?
BT wholesale checker indicates 80-60.4 clean or 80-56.1 impacted. Highest observed is 60.98 (dated yesterday)
Re: Sync speed halved overnight after modem restart - stabilisation?
a month ago
Now found that I have no dialing tone on the landline phone and handset says "line in use". Odd! Maybe me fiddling with the router was just a coincidence and there is something up with the line.
If your phone is out, that will affect the broadband. Report a phone fault: start here https://www.plus.net/help/phone/phone-line-troubleshooting/
Don't worry if the troubleshooter gives an error, it may still have reported a fault. Check your tickets to see.https://www.plus.net/wizard/?p=search
a month ago
Yep, managed to get a ticket submitted earlier using the broadband troubleshooting tool and the ticket info states they have transferred it over to the phone team.
I suppose I should be grateful the line is still working at all for the broadband. If the connection was completely dead I can't see my wife accepting the explanation that it is a totally coincidental line fault and not me messing round with the modem that has caused the issue!
