Sync speed dropped 14th December with no real reason as to why?
- Sync speed dropped 14th December with no real reas...
13-01-2020 9:33 PM
On the 14th of December, it looks as though my line sync speed dropped, and SNR was increased from 3db to 5db. Had quite a bit on in the run up to Christmas, so not really had chance to look into it properly, but just trying to work out what the cause for this may have been? Nothing my side has changed, my model is still reporting an Attainable rate of 67Mbps on the line, yet the sync speeds as seen have dropped from 66.5Mbps to bang on 60Mbps.
Checking the modem stats, there doesn't seem to be any increase in CRC rates or anything else untoward with the connection either which point to there being some kind of fault:
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 59997000 bps US Actual Rate : 19999000 bps
DS Attainable Rate : 67866572 bps US Attainable Rate : 22150000 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 17 dB Cur SNR Margin : 5 dB
DS actual PSD : 7. 2 dB US actual PSD : 12. 8 dB
NE CRC Count : 27 FE CRC Count : 7
NE ES Count : 20 FE ES Count : 4
Xdsl Reset Times : 0 Xdsl Link Times : 2
ITU Version[0] : fe004452 ITU Version[1] : 41590000
VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support]
Power Management Mode : DSL_G997_PMS_L0
Test Mode : DISABLE
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 20 dB Far SNR Margin : 6 dB
CO ITU Version[0] : b5004244 CO ITU Version[1] : 434da49a
DSLAM CHIPSET VENDOR : < BDCM >
Near End Far End Note
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 1 1
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 2 2
LOF : 0 0
LPR : 0 2
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 0 5309 (seconds)
ES : 20 4 (seconds)
SES : 0 1 (seconds)
LOSS : 0 0 (seconds)
UAS : 31 204 (seconds)
HECError : 0 0
CRC : 27 7
RsCorrection : 0 0
INP : 230 220 (symbols)
InterleaveDelay : 0 14 (1/100 ms)
NFEC : 32 32
RFEC : 16 16
LSYMB : 16 16
INTLVBLOCK : 32 32
AELEM : 0 ----
Could anyone from Plusnet shed some light on this please? The connection has been rocking sync speeds of 67Mbps since 24th of August, so seem's a bit odd really!
Re: Sync speed dropped 14th December with no real reason as to why?
15-01-2020 12:38 PM
15-01-2020 3:59 PM
Awesome thanks for the quick response! I'm curious, what reasons usually lead to a line being banded?
16-01-2020 4:37 PM
16-01-2020 8:15 PM
I guess, although the rate of errors on the line doesn't seem to be too bad really, compared to the stats the other day, this is what it's showig now:
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 1 1
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 2 2
LOF : 0 0
LPR : 0 2
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 0 5444 (seconds)
ES : 25 4 (seconds)
SES : 2 1 (seconds)
HECError : 0 0
CRC : 32 7
RsCorrection : 0 0
NFEC : 32 32
RFEC : 16 16
LSYMB : 16 16
INTLVBLOCK : 32 32
AELEM : 0 ----
CRC rate has increased by 5 since Monday which to me isn't bad at all. Remote CRC hasn't increased.
FECS hasn't increase locally but remotely (far end) has increased by 135, but again I'd say that rate shouldn't really have any real effect on this.
Still I'll see what happens over the next few days!
17-03-2020 2:15 PM - edited 17-03-2020 2:18 PM
So it looks like my line has been banded, again... We had a series of powercuts a few days back & seems to have happened following those at around 1:30am on the 16th March. Any solutions to get this to recover itself or is it just a case now of having to put up with it?
DS Attainable Rate : 66997932 bps US Attainable Rate : 21312000 bps
DS actual PSD : 7. 2 dB US actual PSD : 12. 9 dB
NE CRC Count : 0 FE CRC Count : 5076
NE ES Count : 0 FE ES Count : 4665
Xdsl Reset Times : 0 Xdsl Link Times : 3
Test Mode : DISABLE
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 1
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 4 4
LOF : 0 0
LPR : 0 4
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 0 265092 (seconds)
ES : 0 4665 (seconds)
SES : 0 2 (seconds)
UAS : 31 1531 (seconds)
HECError : 0 0
CRC : 0 5076
RsCorrection : 0 0
INP : 0 220 (symbols)
NFEC : 254 32
RFEC : 16 16
LSYMB : 5374 16
INTLVBLOCK : 127 32
AELEM : 0 ----
17-03-2020 2:27 PM
In fact, few things I can see:
G.INP appears to be turned off? (ReTxEnable is disabled) yet we're still supposedly 'Fastpath'
Both LSYMB and INTLVBLOCK have increased dramatically.
I'll give the modem another power cycle, but I'm not holding my breath...
22-03-2020 12:57 PM
