Sync speed declined significantly recently
law
Hi Plusnet!,
Recently my router has only been syncing at about 64mb resulting in a broadband speed of about 59mb. It had previously been synced at around 75-77mb (resulting in a broadband speed of about 71 - 74mb) for the last 18 months or so and has been perfectly stable and consistent.
Oddly I noticed it was also synced at 80mb before this decline to how it is now a few weeks ago. I have been manually rebooting my router relatively frequently over the last couple of weeks to see if it will sync higher which has probably not helped the situation!
Can you see if there are any faults / IP profile stuff you can do please?
5 REPLIES 5
adamwalker
Fixes: 221
Re: Sync speed declined significantly recently
Line tests have picked up on a line fault (a high resistance fault)
I've reported this for you, here' s link for further updates on your account https://www.plus.net/wizard/?p=view_question&id=176652086
 Adam Walker
law
Hi Guys,
I believe the fault on my line has now been cleared but I'm fairly sure I've been "banded" as the sync speed has been exactly 67000 for the last few days.
Is there anything you can do about this to get me back up to full speed?
SammyM
Fixes: 96
Hello @law
Thanks for getting back to us. We can see that it is syncing at 67Mbps, but its not showing as banded as you can see from the test results below.
Can you monitor the connection for a few days and let us know how you get on.
Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 67.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Target Fix Time
Fault Report Advised N
Estimated Line Length In Metres 367.7
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Technology VDSL
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Radio Frequency Ingress
Cross Talk
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
 Sammy M - Sheffield Team
law
I've restarted a couple of times this week and it's still syncing at exactly 67000. It must be being limited or told to sync at that speed by something as it wouldn't normally be such a round number. Is this an "IP profile" thing you can reset please? When the engineer came his device was syncing at 76-78mb.
Thanks!
EmilyD
Fixes: 117
Hi @law thanks for getting back in touch.
I've tested your line today and it's still syncing at 67mbps, however the test isn't showing any banding on the line and it isn't picking up any underlying faults. As 67mbps is within the estimates for your line, there isn't anything that we can do to increase the speed I'm afraid.
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXX
Test Outcome Pass
Sync Status In Sync
Cross Talk Not Detected
Estimated Line Length In Metres 348.6
Technology VDSL
Time Stamp 2018-06-15T00:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 67.0 Mbps 73.2 Mbps 67.3 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 318.0 Sec 900.0 Sec 898.3 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-06-21T10:46:09.459+01:00 2018-06-21T11:01:09.459+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Emily D
