Sync Speeds fluctuate between 50 & 60mbps
- Sync Speeds fluctuate between 50 & 60mbps
14-03-2015 12:44 PM
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 64.1 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Profile Name 0.128M-67M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2015-02-16T09:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 50.3 Mbps 63.8 Mbps 53.0 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 0.0 Sec 908.0 Sec 897.9 Sec
Retrains 0.0 43.0 0.0
Estimate:
FTTC Range A (Clean) 77.6 57.9 20 18.9 -- Available
FTTC Range B (Impacted) 70 41.3 20 12.2 -- Available
Summary:
Downstream showing 14Mbps flctuations. In speed. Will raise fault.
GEA Test Detail
Circuit ID NA Service ID BBEU10321113
Test Outcome Pass
Sync Status In Sync
Downstream Speed 67.0 Mbps
Profile Name 0.128M-67M Downstream, Interleaving High - 0.128M-20M Upstream, Interleaving On
Time Stamp 2015-02-25T13:45:00
Down Stream Line Rate 50.4 Mbps 67.0 Mbps 60.5 Mbps
Up Time 866.0 Sec 944.0 Sec 900.0 Sec
Retrains 0.0 1.0 0.0
Hi all
PN are requesting an engineers visit - could anyone throw any light on what is causing this?
The results are showing that you should be currently achieving 67Mbps with interleaving on but you would not be able to achieve any higher speeds due to this restriction.
However the test indicates that your SYNC speeds tend to fluctuate between 50Mbps - 60Mbps.
Thanks in Advance
Sync Status In Sync
Estimate:
Summary:
GEA Test Detail
Test Outcome Pass
Sync Status In Sync
Hi all
Thanks in Advance
Message 1 of 2
(608 Views)
1 REPLY 1
Re: Sync Speeds fluctuate between 50 & 60mbps
16-03-2015 9:49 AM
Quote PN are requesting an engineers visit - could anyone throw any light on what is causing this?
It could be a number of things, unfortunately the testing isn't showing us exactly what it is so we need to get an engineer out.
Message 2 of 2
(294 Views)
