Sync Speed FTTC
- Sync Speed FTTC
Sync Speed FTTC
19-01-2021 11:07 AM
Hi
I recently had a fault on my line and afterwards I had really good sync speeds at around 55mbs but over the last few days its dropped to 48mbs.
I have a draytek 130 vdsl modem and here is the current output:
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 48996000 bps US Actual Rate : 5993000 bps
DS Attainable Rate : 60514392 bps US Attainable Rate : 5771709 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 757 US Interleave Depth : 96
NE Current Attenuation : 17 dB Cur SNR Margin : 1 dB
DS actual PSD : 5. 4 dB US actual PSD : 5. 6 dB
NE CRC Count : 6 FE CRC Count : 15482
NE ES Count : 1 FE ES Count : 10895
Xdsl Reset Times : 0 Xdsl Link Times : 2
ITU Version[0] : fe004452 ITU Version[1] : 41590000
VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support]
Power Management Mode : DSL_G997_PMS_L0
Test Mode : DISABLE
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 19 dB Far SNR Margin : 6 dB
CO ITU Version[0] : b5004946 CO ITU Version[1] : 544eb206
DSLAM CHIPSET VENDOR : < IFTN >
Can any one shed any light to why the attainable rate is at 60mbs?
Does my IP profile need resetting to sot the sync speed?
Any help would be great.
Re: Sync Speed FTTC
19-01-2021 11:35 AM
Your 'Curr SNR' at 1 dB sounds far to low. It is interesting that ATU-C is 6 dB, where you might expect it. This could be causing multiple errors on the line. Have you tried dropping the connection to see is resynchronising your modem with the FTTC cabinet helps?
Re: Sync Speed FTTC
19-01-2021 11:42 AM
Hi
I have tweaked the snr to -50,should I set it back to 0?
Re: Sync Speed FTTC
19-01-2021 11:49 AM
I am unfamiliar with this modem and cannot conceive why you would do this. I would return it to it's factory setting or preferably plug in your Plusnet supplied hub to get an idea as to whether you have a real problem or it is caused by your changing the modem settings.
Re: Sync Speed FTTC
19-01-2021 12:31 PM
No worries, the tweak has increased the sync speed on default settings its about 35 mb
I do not have a plus net router as I use an enterprise firewall to connect to the pppoe port on the draytek.
Re: Sync Speed FTTC
20-01-2021 12:14 AM
Re: Sync Speed FTTC
20-01-2021 7:47 AM
Thanks, I will set SNR back to 0 and will raise a case with plus net again!
Minimum Guaranteed Speed is 50Mbps but currently syncing at 38mbs!
