Sync Speed Dropping
p4thf1nd3r
Sync Speed Dropping
Over the past 6 week my sync has dropped from 63mbps to 46mbps. Also My router keeps disconnecting from several devices. I split the 2.4GHZ and 5GHZ Networks and it has improved slightly... It may be the case that the router is dropping connection to the DSLAM causing DLM to limit my line speed.
I raised a ticket on the 4th Feb but so far nobody has picked this up.
 Ticket No #167688745
Fixes: 68
Re: Sync Speed Dropping
The line has been stable for over 8 days but diagnostics have picked up on a fault.
Before I can progress the fault ticket any further can you tests speeds over a cabled LAN connection to see if they differ much?
Adam
 Adam Walker
p4thf1nd3r
BT Speed Test says im getting 300mbps ... I wish that was accurate.
p4thf1nd3r
Speedtest.net is showing as 43.82mbps
p4thf1nd3r
p4thf1nd3r
BTW Performance Test
Fixes: 203
Apologies for the delayed response.
We'll get your fault updated shortly.
 Matthew Wheeler
