Sync Speed Dropping
- Re: Sync Speed Dropping
Sync Speed Dropping
07-02-2018 10:04 PM - edited 07-02-2018 10:04 PM
Over the past 6 week my sync has dropped from 63mbps to 46mbps. Also My router keeps disconnecting from several devices. I split the 2.4GHZ and 5GHZ Networks and it has improved slightly... It may be the case that the router is dropping connection to the DSLAM causing DLM to limit my line speed.
I raised a ticket on the 4th Feb but so far nobody has picked this up.
Ticket No #167688745
08-02-2018 1:47 PM
The line has been stable for over 8 days but diagnostics have picked up on a fault.
Before I can progress the fault ticket any further can you tests speeds over a cabled LAN connection to see if they differ much?
Adam
08-02-2018 8:38 PM - edited 08-02-2018 8:40 PM
BT Speed Test says im getting 300mbps ... I wish that was accurate.
08-02-2018 8:39 PM - edited 08-02-2018 8:41 PM
Speedtest.net is showing as 43.82mbps
08-02-2018 8:46 PM
Speedtest.Net
08-02-2018 8:47 PM
BTW Performance Test
13-02-2018 3:08 PM
