Sync Speed Dropped
- Sync Speed Dropped
Sync Speed Dropped
07-02-2019 12:53 PM
Hi, I recently joined Plusnet and switched from the HubOne to a BT Business Smarthub 6
Up until recently I was Syncing at over 60MB but recently its dropped to 55MB
Is it possible to run any tests or reset to get my Sync Speed back up?
Thanks in advance
Re: Sync Speed Dropped
07-02-2019 1:52 PM - edited 07-02-2019 1:52 PM
Hi there.
I've tested your line and our tests aren't showing the cause for the speed drop or anything we can do to improve this as your speeds are within estimates of between 47.1mbps to 67.6mbps.
When you plug your Hub One back in do your sync speeds increase?
Also here's a copy of our testing if you're interested:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 55.8 Mbps |
Upstream Speed | 17.7 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 616.0 |
Upstream Rate Assessment | Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2019-01-25T14:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 55.7 Mbps | 65.7 Mbps | 56.3 Mbps |
Up Stream Line Rate | 16.8 Mbps | 17.7 Mbps | 17.6 Mbps |
Up Time | 762.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-07T13:31:16.861+00:00 | 2019-02-07T13:46:16.861+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
07-02-2019 1:59 PM
Sync Speeds were fairly similar on the Hub One.
They improved when i switched to the Business Hub but dropped back again.
I can't complain, your test results are almost identical to the Router Stats
07-02-2019 2:02 PM
07-02-2019 2:05 PM
55.79 Mbps
17.70 Mbps
07-02-2019 2:10 PM
If you go to the Troubleshooting > Helpdesk tab you should see two rows: Data rate and Maximum data rate. The data rate is basically your sync rate and the maximum is what is theoretically achievable.
07-02-2019 2:12 PM
07-02-2019 2:17 PM
Thanks for that, it may be worth trying the steps Here to try to improve your sync speeds further.
09-02-2019 1:08 PM
Swapped the Included RJ11 Cable for a Shorter 20cm one and have seen some improvements.
58.43 Mbps
18.34 Mbps
09-02-2019 8:36 PM
Hi @scjgreen,
I'm glad to see that your speeds have improved somewhat since setting the router up within the test socket. It may be worth leaving the router in this setup and monitoring the connection speeds to see if they improve further going forward.
09-02-2019 8:53 PM
10-02-2019 6:55 PM
Hi @scjgreen,
Thanks for coming back to us. It might be worth using the test socket too to see if it helps improvements further.
Thanks - LF
