Sync Speed Dropped
scjgreen
Sync Speed Dropped
Hi, I recently joined Plusnet and switched from the HubOne to a BT Business Smarthub 6
Up until recently I was Syncing at over 60MB but recently its dropped to 55MB
Is it possible to run any tests or reset to get my Sync Speed back up?
Thanks in advance
11 REPLIES 11
Fixes: 1,600
Re: Sync Speed Dropped
Hi there.
I've tested your line and our tests aren't showing the cause for the speed drop or anything we can do to improve this as your speeds are within estimates of between 47.1mbps to 67.6mbps.
When you plug your Hub One back in do your sync speeds increase?
Also here's a copy of our testing if you're interested:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 55.8 Mbps
Upstream Speed 17.7 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 616.0
Upstream Rate Assessment Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-01-25T14:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 55.7 Mbps 65.7 Mbps 56.3 Mbps
Up Stream Line Rate 16.8 Mbps 17.7 Mbps 17.6 Mbps
Up Time 762.0 Sec 900.0 Sec 899.7 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-02-07T13:31:16.861+00:00 2019-02-07T13:46:16.861+00:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
scjgreen
Sync Speeds were fairly similar on the Hub One.
They improved when i switched to the Business Hub but dropped back again.
I can't complain, your test results are almost identical to the Router Stats
Fixes: 1,600
Ah fair, out of curiosity what's the maximum data rate showing as?
scjgreen
55.79 Mbps
17.70 Mbps
Fixes: 1,600
If you go to the Troubleshooting > Helpdesk tab you should see two rows: Data rate and Maximum data rate. The data rate is basically your sync rate and the maximum is what is theoretically achievable.
scjgreen
17809 / 66080
Fixes: 1,600
Thanks for that, it may be worth trying the steps Here to try to improve your sync speeds further.
scjgreen
Swapped the Included RJ11 Cable for a Shorter 20cm one and have seen some improvements.
58.43 Mbps
18.34 Mbps
TheMightyAJ
Fixes: 126
Hi @scjgreen,
I'm glad to see that your speeds have improved somewhat since setting the router up within the test socket. It may be worth leaving the router in this setup and monitoring the connection speeds to see if they improve further going forward.
 Alex H
scjgreen
I didn't use the test socket, just a shorter cable
LordFoul
Fixes: 32
Hi @scjgreen,
Thanks for coming back to us. It might be worth using the test socket too to see if it helps improvements further.
Thanks - LF
