turn on suggestions
Syn speed and profile
- Syn speed and profile
02-06-2015 11:26 PM
Could I have some information on my sync speed and profile?
Re: Syn speed and profile
03-06-2015 11:30 AM
03-06-2015 9:57 PM
Many thanks. When BT test the line before installation he noted that the line speed is 24mbps and the upload is 18mbps. When first connected my downloads has been around 21mbps but upload has never been over 2mbps.
But as per your reply regarding my sync speed at 18mbps, my download speed is down to 17mbps and upload at 1mbps. Also this page here from plusnet showing current line speed of 40mbps (https://portal.plus.net/my.html?action=data_transfer_speed).
03-06-2015 10:08 PM
Further check on http://www.speedtest.btwholesale.com/
1. Best Effort Test: -provides background information.
Download Speed
16.71 Mbps
0 Mbps 21.36 Mbps
Max Achievable Speed
Download speedachieved during the test was - 16.71 Mbps
For your connection, the acceptable range of speedsis 17.09 Mbps-21.36 Mbps .
Additional Information:
IP Profile for your line is - 21.36 Mbps
Upload Speed
1.02 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 1.02Mbps
Download Speed
16.71 Mbps
0 Mbps 21.36 Mbps
Upload Speed
1.02 Mbps
0 Mbps 20 Mbps
03-06-2015 10:19 PM
3rd test indicate some issue and ip profile changed to 17.6 (http://test3.speedtest.btwholesale.com/PerformanceTesterWS/indexTap3Frames.jsp?BBIP=01824xxxxxx&serviceId=&TAP=3&BBD=), please see below
Download Speed
16.6 Mbps
0 Mbps 17.6 Mbps
Download speedachieved during the test was - 16.6 Mbps
For your connection, the acceptable range of speedsis 14.08 Mbps-17.6 Mbps .
IP Profile for your line is - 17.6 Mbps
Upload Speed
0.8 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 0.8Mbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
Download Speed
16.6 Mbps
0 Mbps 17.6 Mbps
Upload Speed
0.8 Mbps
0 Mbps 20 Mbps
