Switching from Sky fibre
- Switching from Sky fibre
06-01-2016 4:00 AM
My Plusnet hub is due to arrive and I am unable to order Youview until then. This means continuing with Sky for another week.
Can I continue with the Sky router until then? If I have to use the Plusnet router will it access Sky Demand?
Any advice will be much appreciated.
Message 1 of 3
(771 Views)
2 REPLIES 2
Re: Switching from Sky fibre
06-01-2016 7:06 AM
Once you have switched to Plusnet Fibre your Sky router will no longer work.
Your new Plusnet router will work with Sky On Demand, you just need to go to the network settings within your Sky Box (if using WiFi to connect) and reset the connection.
Message 2 of 3
(493 Views)
06-01-2016 8:02 AM
That's great.
Many thanks for your help.
mav:quote
mav:quote
Message 3 of 3
(493 Views)
