Switching from BT to Plusnet when cabinet is full
plusmore
I currently have BT Infinity 2 and am looking to move to Plusnet in June when my contract ends as BT is just way too expensive. As I already have a port in my local cabinet which OpenReach are reporting as full and waitlisting new orders will my transfer still be able to proceed or will I lose my FTTC if I try to switch?
MattyC
Champion
Fixes: 46
Re: Switching from BT to Plusnet when cabinet is full
As this is a migration order, you shouldn't lose your port.
If you sign up with us, feel free to PM your username over and I'll check your order.
Matty
plusmore
A couple of other questions
  1. Can I define the start date so I get the order into the system so the service switches over on the day my BT contract ends (in June)?
  2. Will I need a MAC code or do PN handle everything?
Fixes: 31
Having done the same as you last year, yes place your order in advance, BT require 30 days notice, if you want to avoid double billing, so place your PN order a day or two before your last 30 days. Don't say anything to BT, let PN arrange the takeover. No MAC needed.
oh, and keep the email you should get from BT saying someone has requested taking over your line. You may need this if BT try and charge you a £30 cancellation fee. Also don't be alarmed if BT send you a bill after the service has been transferred, the bill in advance, so sometimes it takes them a few days to get it sorted.
HTH
Fixes: 6
Have you asked BT if they will do a retention deal. Wink
plusmore
Not sure they will be able to match PN, current costs will be £36 per month plus Line Rental, PN are over £10 per month cheaper and having been a customer in the past was happy with their service. Also, can grab some cashback via Quidco/Topcashback to sweeten the deal. BT seem to be taking money out of phone and BB users to subsidise their BT TV and EE purchases.
Fixes: 6
Can't argue with that, I've just had a massive payout for moving the other way. Funny
plusmore
PM sent with username
MattyC
Champion
Fixes: 46
Thanks! I've responded to your PM.
No problems with your order and the ports won't change.
Matty
