Switching cabinets
- Switching cabinets
Re: Switching cabinets
30-10-2015 2:24 PM
30-10-2015 2:27 PM
I understand the frustration but moving cabinet isn't something we'd be able to request, and we are providing a service within the estimates agreed when the contract was signed up.
30-10-2015 2:37 PM
30-10-2015 2:41 PM
Quote from: Anotherone I didn't say anything about placing an order! I said find out if a pair is available in the first place.
And that would help the OP how? To have a new line, you need to place an order.
30-10-2015 2:48 PM
30-10-2015 3:05 PM
30-10-2015 3:23 PM
30-10-2015 4:26 PM
Quote from: AndyH And that would help the OP how? To have a new line, you need to place an order.
Do you work for Plusnet Provisioning? No. So how do you know that one of the more senior staff in Provisioning can't ask a contact in OpenReach about the situation? But hey, come to think of it, with all the OpenReach information that you have access to, if the OP tells you the Exchange, Cab and DP, you could look it up, eh?
Edit: spelling.
30-10-2015 4:32 PM
Quote from: Anotherone Do you work for Plusnet Provisioning? No. So how do you know that one of the more senior staff in Provisioning can't ask a contact in OpenReach about the situation?
Perhaps you've missed what Chris said above?
30-10-2015 4:36 PM
As Chris has already stated, records for the address show Cabinet 1. If this was just changed off the back of a phone call to Cabinet 10, then that would make current cabling/routing incorrect and cause data integrity issues.
Unfortunately as has been mentioned previously, we won't be able to re-route the line to a different cabinet and won't be able to get a new line installed from a different cabinet, due to the routing details for the address.
30-10-2015 4:39 PM
I did NOT suggest that is was changed off the "back of a phone call", I suggested somebody ask questions of Openreach!
@AndyH
As you don't work for Plusnet and you can't look up the data, your remarks are somewhat meaningless.
@Chris or HarryB
Have you spoken to anyone senior enough in provisioning to see what information they might be able to get from a contact in Openreach?
Have you asked if they can get a quote for an engineer to climb the pole and switch the pair - Officially?
30-10-2015 4:41 PM
The only reason I can imagine why a second cabinet might be connected to an existing pole would be if the existing cabinet (or cable to pole) had no more capacity when such capacity were required at the particular pole and it was impractical to increase capacity at/from the existing cabinet. I suppose there may be a possible case where cable damage reduces the number of pairs available to the pole and it's cheaper to run a line from somewhere else in the vicinity than to replace a particular cable if it is 'beyond repair'.
BT OR understandably avoid, as much as possible, anything requiring digging, laying new ducting or running new multi-pair cables.
Unless someone can suggest other reasons why a pole may have multiple cabinet feeds (or tell me it's not as unusual as I imagine) then I also imagine that any request for a new line will be provided strictly from whichever cabinet/cable has the capacity (spare pair(s)) available - that's not to say that there couldn't be dialogue at an appropriate level to actually find out what could/would be done if a new line were requested.
30-10-2015 4:43 PM
30-10-2015 4:58 PM
If the records for an address state a line should be connected to cabinet 1, and the line is connected to cabinet 1. Everything is as it should be from a provisioning point of view.
If the records for an address state a line should be connected to cabinet 1, and we place an order with our suppliers, or ask them where they will connect the line, they will connect this to the cabinet advised in the routing details for the line.
I have seen it in the past where a line is connected to a cabinet different to the one advised on the records, at which point the line was re-routed to the correct cabinet. However as this situation currently stands, the line is connected to the correct cabinet as per the records for the address and the line.
Further than this, I'm slightly confused as to what you expect us to ask Openreach.
30-10-2015 5:24 PM
Well I thought what JK wanted as mentioned in the OP was clear.
Jim also summarised it in reply #8.
So based on the information already provided in the thread, ask Openreach is there a spare pair between DP (whatever, not mentioned here) and Cabinet 10? What would it cost to move someone from that DP on Cabinet 1 to Cabinet 10 and how would you place an order for that if possible?
Failing that, and if a spare pair were available, can an order for a new (separate) line be placed and for it to be connected to Cabinet 10 and how would you place such a specific order?
I really don't see that it's not possible for a human to human contact to ask those questions. We all know that the current Plusnet and Openreach provisioning systems have their "limitations" (I'm being polite), but really, this computer says no stuff shouldn't prevent Dialogue!
And if Plusnet really can't manage that, then I refer JK back to what spoon whittler said in reply #12 and what I said in reply #17.
