Switching cabinets
- Switching cabinets
Switching cabinets
23-04-2016 2:35 PM
I am on fibre at the moment which my nearest cabinet is a couple of streets away & i get about 8mbps, in the last few days there has been a new cabinet built outside my house & i wondered how i could get connected to it as its so near ?
please help.
Re: Switching cabinets
23-04-2016 3:51 PM
if you find out, many people would be interested. The normal answer given (on other sites) is that you cannot get changed between cabinets.
23-04-2016 4:10 PM
I don't believe that's possible There isn't any way for the public to contact Openreach, even then as your already connected else where they are not going to disconnect you from it just because there is now a cab outside your home, as you say yourself your connected to one that is streets away it wouldn't surprise me if the new cab is to serve those streets away from you.
23-04-2016 7:52 PM
Is it actually a BT Fibre Cab? In any event, also critical to all this is where your PCP Cab is!
24-04-2016 9:18 AM
Before I moved location, my pcp cab was on a different estate to the one I was living on. Nothing I could do about it unfortunately
If you Like it, give it a
24-04-2016 12:36 PM
Maybe a 2nd line would be, then cancel the first. Bit of a gamble though.
24-04-2016 12:50 PM
It could be a gamble indeed. You'd certainly be advised to use the DSL Checker to see what speeds are being predicted. A postcode may give a different result from a phone number if there is no plan to move lines (certainly not guaranteed).
In the particular example given above, there are two significant points -
If it is indeed an Openreach Fibre Cab, you don't know what Openreach are planning to do with it. They might be planning to transfer some lines BUT it might just be to provide some additional Fibre circuits.
Secondly, as I mentioned before, it's the distance from the PCP cabinet that is also significant because there will be jumper cables between the PCP and the Fibre cab, so it's the total distance from the Fibre Cab to the PCP and then from PCP to the EU that's important.
There are instances where new combined PCP & Fibre Cabs are being installed, I don't know if there is information about where those might be. In any case, if a Cab has just been installed it will be weeks/months before it becomes active.The best bet for information is to go and chat to an Openreach engineer when you see one working on the Fibre Cab.
25-04-2016 7:10 PM
Thanks everyone for your replies i will investigate on predicted speeds from different cabs & then try & do some shouting about & see what comes up, thanks again all
25-04-2016 7:14 PM
Justa thought, if i were to change ISP would BT not then re connect me to the nearest cabinet ? Or is that to logical ?
25-04-2016 7:52 PM
No, your connection will not change just by moving ISP and remaining on Fibre. As I said, have a chat with the Openreach engineers and see what is planned for that Cabinet.
And you won't be able to "investigate" predicted speeds from "different" cabs, that's not how the system works. The reason I suggested using a postcode (rather than your phone number - which will only give what you've got) is that if houses in your postcode not currently on Fibre are going to be connected to the new Cab, it may give different speed estimates, but I'd guess you may not get that sort of data anyway until the Cab is active as it won't show on the system.
