Switched to fritzbox 7390 and now Max. DSLAM throughput suddenly 40000 ?
- Re: Switched to fritzbox 7390 and now Max. DSLAM t...
13-05-2016 12:59 PM
So I switched to a fritzbox 7390 a couple of days ago and got a beta firmware from AVM and was getting a decent speed but had to relocate the box which meant I disconnected it several times.
Since reconnecting I am suddenly getting a Max. DSLAM throughput of 40000 instead of the 80000 and also now have an SNR of 8db
My line supports around 50mb so hoping maybe a plusnet staff member can look into this?
Re: Switched to fritzbox 7390 and now Max. DSLAM throughput suddenly 40000 ?
13-05-2016 2:58 PM
I'm guessing you had a DLM intervention due to disconnections (while you moved the box), and it's increased your SNR in the process. It should settle back to normal in a couple of days.
19-05-2016 6:02 PM
Yep DLM read it as line instability, it will return to normal in a few days
