Switched to fibre but not working
Fixes: 1,600
Re: Switched to fibre but not working
Sorry to hear you're still having problems. Sad
I have contacted our suppliers, and due to resourcing issues they have been unable to fix the system issues around the fault report to progress it to an engineer. We've been given another 48 hours for this to be resolved.
I've also just raised an escalation, we'll let you know the outcome of this later today.
Apologies for any inconvenience caused.
Fixes: 1,600
Just checking up on this for you.
It looks like your fault was progressed to an engineer today, and it appears your router may be faulty.
Let us know how you get on when the new router arrives.
andrewpurkis201
he put his tester on and it was saying the line is working but it wouldnt authenticate
he tried moving the line in the fibre cabinet to another port and it still showed the line was working but still wouldnt authenticate
so he call you and checked UN and PW were ok and still no authenticating
so you said that maybe it was the router?
still really unhappy with this as its been over a week now ive had to use my phone internet and its costing me a fortune
but just have to wait and see if the hub fixes the problem
RealAleMadrid
Aspiring Hero
Fixes: 59
Are you saying that the BT guy called PlusNet and they confirmed your username and password to him? That should not happen for data protection reasons. The fact that PlusNet think that you were connected briefly when first upgraded suggests the router is not faulty, I suspect that there is still some BT problem that has not been fixed yet.
@Gandalf Can you check if any connection attempts have been made on the OP's line?
Chris
Legend
Fixes: 169
Sorry that you're still having issues Andrew. Let us know how it goes with the new router when it arrives. -Chris
andrewpurkis201
the fibre connection has NEVER worked
when i upgraded from adsl they sent me a hub one which i installed and that worked on my adsl connection fine
but when they disconnected my adsl and switched to the fibre cab its stopped working and hasnt since
it just tries to connect PPP but wont authenticte
me and the Openreach chap tried everything and I called PN and we checked the UN/PW was correct
his tester showed my 40/2 connection and he had a old openreach modem box and that got sync at 40/2
and looking in the plusnet one stats it shows the 40/2 connection
but it has never authenticated
Fixes: 1,600
Looking into this further, honestly we don't believe your router is faulty (as you pointed out it was working with your ASDL connection). I think the next step is to arrange another engineer to take another shot at fixing this.
I'm in the process of contacting our suppliers to get the option for another appointment. I'll update your ticket shortly.
Fixes: 48
Has a factory reset of the router been tried?
Fixes: 1,600
Thanks for your patience @andrewpurkis201
After a very lengthy conversation with our suppliers, they have raised a manual task with Openreach to progress your fault as the report is still stuck within their systems.
We expect an engineer to be working at the exchange as soon as they possibly can, which is tomorrow. We will check back on this for you tomorrow. I apologise for the inconvenience caused.
andrewpurkis201
new router arrived this morning so plugged in and no different
still no internet
looking at the troubleshooting page it shows sync at 40/2 but it just does the PPP authenticating and nothing
same issue
Fixes: 1,600
Honestly, I didn't think it was a router fault.
After another lengthy conversation with our suppliers, the fault report is stuck in the Openreach systems again and this hasn't progressed to a non appointed task as per my previous conversation with them yesterday.
We're due another update later today to the Escalation I've raised. In the meantime, I've requested this to be escalated to the next level. I appreciate that this isn't really the update you'd want to hear, I'm a bit disappointed myself to be honest.
We'll keep you updated, thanks for your patience.
Fixes: 1,600
Just an update, our suppliers have advised us that your fault report is in hand with their ASG team and it should progress by tomorrow. We'll keep you updated either here or via the ticket on your account.
andrewpurkis201
it always seems to be tomorow
i am at a loss now im so angry it just seems to be stuck in a circle with it always being tomorrow
it been nearl 2 weeks and im paying for something ive never had
Fixes: 1,600
I understand and appreciate your frustration.
I'm doing all we can to get this progressed.
andrewpurkis201
well its another day and still nothing and no call or anything
so now its the bank holiday so ill be without internet thiss tuesday???
this is completely unacceptable to keep fobbing me off
i mean hold long am i suppsed to wait? 2 week 3? a month?
